Salta al contenuto principale
Motorola Moto E4 Plus Front-Facing Camera Replacement
Cosa ti serve
  1. Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the back cover: passo 1, immagine 1 di 3 Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the back cover: passo 1, immagine 2 di 3 Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the back cover: passo 1, immagine 3 di 3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Front-Facing Camera Replacement: passo 2, immagine 1 di 2 Motorola Moto E4 Plus Front-Facing Camera Replacement: passo 2, immagine 2 di 2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the midframe screws: passo 3, immagine 1 di 1
    • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
  4. Motorola Moto E4 Plus Front-Facing Camera Replacement, Release the midframe clips: passo 4, immagine 1 di 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Release the midframe clips: passo 4, immagine 2 di 2
    • The plastic midframe is still held in place with clips.
    • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
    • Twist the spudger to release the plastic clip.
    • Repeat the process for the clip near the top right corner of the phone.
  5. Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the midframe: passo 5, immagine 1 di 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the midframe: passo 5, immagine 2 di 2
    • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
    • Remove the plastic midframe.
    • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
  6. Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the battery: passo 6, immagine 1 di 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the battery: passo 6, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
  7. Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the display cable: passo 7, immagine 1 di 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the display cable: passo 7, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the display cable from its motherboard socket, near the bottom left corner of the motherboard.
  8. Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the antenna cable: passo 8, immagine 1 di 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the antenna cable: passo 8, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the antenna cable from its motherboard socket.
  9. Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the interconnect cable: passo 9, immagine 1 di 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the interconnect cable: passo 9, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the interconnect cable from its motherboard socket.
  10. Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the motherboard screws: passo 10, immagine 1 di 1
    • Remove the two black 3.2 mm long T3 screws securing the motherboard.
  11. Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the motherboard: passo 11, immagine 1 di 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the motherboard: passo 11, immagine 2 di 2
    • Grasp the motherboard by the top corners and lift it out of the phone.
    • Remove the motherboard.
  12. Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the front-facing camera: passo 12, immagine 1 di 2 Motorola Moto E4 Plus Front-Facing Camera Replacement, Disconnect the front-facing camera: passo 12, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the front-facing camera from its motherboard socket.
  13. Motorola Moto E4 Plus Front-Facing Camera Replacement, Remove the front-facing camera: passo 13, immagine 1 di 1
    • Flip the motherboard over.
    • Remove the front-facing camera.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto E4 Plus Answers community for help.
Arthur Shi
Membro da: 01/03/18
258.910 Reputazione
531 Guide realizzate
iFixit Membro di iFixit
Staff
140 Membri
18.077 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 279
