Introduzione
To remove the speaker you will first need to remove the battery, open the phone and remove the motherboard. Be ready to use a plastic opening tool, T5 Torx Screwdriver, spudger and head gun or hair dryer.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:T5 Torx Screwdriver$5.49
Remove the four 5.0 mm T5 Torx screws using a T5 Torx Screwdriver.
Remove the three 5.5 mm T5 Torx screws using a T5 Torx Screwdriver.
Attrezzo utilizzato in questo passaggio:iFixit Opening Tool$1.99
Lift up the black rubber flap using an opening tool.
Remove the single 5.5 mm T5 Torx screw using a T5 Torx Screwdriver.
Gently lift the tabs located at the top of the phone using an opening tool.
Gently lift the tab located at the bottom of the phone with the same tool.
Insert an opening tool between the front and back of the case.
Slide the tool down the side of the phone.
Repeat the same process for the other side.
Slide an opening tool beneath the antenna and lift straight up from the motherboard.
Attrezzo utilizzato in questo passaggio:Spudger$3.99
Insert a spudger between the black plastic and the motherboard.
Lift upwards with the spudger to dislodge the board.
In order to get to the top speaker, first remove the rubber cover located directly over the speaker.
The orange adhesive strip needs to be peeled off in order to remove the top speaker. This can be done using fingernails or the spudger tool.
Using the spudger, lift up from under the top speaker and it should slide easily out of place.
Be careful when removing top speaker out of its housing because it is still connected to the phone. You must undo the connection indicated with the orange circle before complete removal.
To undo the connector lift the black flap up - edge closest to the speaker - then the cable slides out
Altre 9 persone hanno completato questa guida.
