Motorola Atrix 4G LCD Replacement
Introduzione
Vai al passo 1To remove the LCD you will first need to remove the battery, open the phone and remove the motherboard. Be ready to use a plastic opening tool, T5 Torx Screwdriver, spudger and head gun or hair dryer.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:T5 Torx Screwdriver$5.49
Remove the four 5.0 mm T5 Torx screws using a T5 Torx Screwdriver.
Remove the three 5.5 mm T5 Torx screws using a T5 Torx Screwdriver.
Attrezzo utilizzato in questo passaggio:iFixit Opening Tool$1.99
Lift up the black rubber flap using an opening tool.
Remove the single 5.5 mm T5 Torx screw using a T5 Torx Screwdriver.
Gently lift the tabs located at the top of the phone using an opening tool.
Gently lift the tab located at the bottom of the phone with the same tool.
Insert an opening tool between the front and back of the case.
Slide the tool down the side of the phone.
Repeat the same process for the other side.
Slide an opening tool beneath the antenna and lift straight up from the motherboard.
Attrezzo utilizzato in questo passaggio:Spudger$3.99
Insert a spudger between the black plastic and the motherboard.
Lift upwards with the spudger to dislodge the board.
Using a heat gun or a hair dryer on high heat, soften the adhesive securing the glass screen.
With the glass removed you can now access the LCD screen.
Using a plastic opening tool, slide it in between LCD screen and the case of the phone and then pry it out carefully.
Slide the case opener tool along the side until the LCD pops out of the case.
Carefully guide the cables attached to the back of the LCD through the hole.
Altre 4 persone hanno completato questa guida.
