Introduzione
Use this guide to replace a broken or cracked screen assembly in the Motorola Moto C Plus.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
You may need need replacement adhesive to reattach components during reassembly.
Cosa ti serve
Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
Lever the battery out of its recess and remove it.
Remove the six 3.1 mm Phillips #00 screws securing the daughterboard cover.
Remove the two 3.2 mm Phillips #00 screws securing the motherboard.
Prepare an iOpener and apply it to the bottom part of the display for at least two minutes to loosen the adhesive beneath the daughterboard.
Use an iOpener and apply it to the top edge of the display to loosen the adhesive beneath the earpiece speaker.
Use an iOpener to loosen the adhesive tape that sits on top of the interconnect and display flex cable. Apply the iOpener on the tape for at least two minutes.
Altre 3 persone hanno completato questa guida.
