Salta al contenuto principale
Motherboard Replacement
Cosa ti serve
  1. Motherboard Replacement, Back Cover: passo 1, immagine 1 di 3 Motherboard Replacement, Back Cover: passo 1, immagine 2 di 3 Motherboard Replacement, Back Cover: passo 1, immagine 3 di 3
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Motherboard Replacement: passo 2, immagine 1 di 1
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Motherboard Replacement, Battery: passo 3, immagine 1 di 1
    • Remove masking tape from the battery.
  4. Motherboard Replacement: passo 4, immagine 1 di 3 Motherboard Replacement: passo 4, immagine 2 di 3 Motherboard Replacement: passo 4, immagine 3 di 3
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Motherboard Replacement: passo 5, immagine 1 di 3 Motherboard Replacement: passo 5, immagine 2 di 3 Motherboard Replacement: passo 5, immagine 3 di 3
  6. Motherboard Replacement, Motherboard: passo 6, immagine 1 di 3 Motherboard Replacement, Motherboard: passo 6, immagine 2 di 3 Motherboard Replacement, Motherboard: passo 6, immagine 3 di 3
    • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
    • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
  7. Motherboard Replacement: passo 7, immagine 1 di 1
    • Use the nut driver and J00 bit to remove the three 4 mm screws.
  8. Motherboard Replacement: passo 8, immagine 1 di 3 Motherboard Replacement: passo 8, immagine 2 di 3 Motherboard Replacement: passo 8, immagine 3 di 3
    • Peel back metal tape that is hiding the auxiliary port wires.
    • Remove tape that is holding the speaker wires in place.
    • Lift up on the motherboard to release it from the tablet.
Conclusione
Connor Fisher
Membro da: 11/04/16
212 Reputazione
1 Guida realizzata
Baylor, Team 4-1, Williams Fall 2016 Membro di Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
4 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 313
