Salta al contenuto principale
Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement
  1. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade Cover: passo 1, immagine 1 di 3 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade Cover: passo 1, immagine 2 di 3 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade Cover: passo 1, immagine 3 di 3
    • Before you begin, make sure to power off and unplug the device from the outlet.
    • If the clear water pump hose is connected, remove it now.
    • Loosen the plastic knob holding the saw's cutting head in place.
    • Lower the cutting head while keeping it steady.
  2. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: passo 2, immagine 1 di 2 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: passo 2, immagine 2 di 2
    • Unscrew the knob.
    • Remove it from the cutting head.
  3. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: passo 3, immagine 1 di 2 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: passo 3, immagine 2 di 2
    • Loosen the plastic knob holding the blade cover in place.
  4. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: passo 4, immagine 1 di 3 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: passo 4, immagine 2 di 3 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: passo 4, immagine 3 di 3
    • Loosen the wing nut on the blade cover pivot shaft.
    • Remove the wing nut and accompanying washer.
  5. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: passo 5, immagine 1 di 2 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: passo 5, immagine 2 di 2
    • Pivot the blade cover up and pull it off the shaft.
  6. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade: passo 6, immagine 1 di 3 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade: passo 6, immagine 2 di 3 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade: passo 6, immagine 3 di 3
    • Insert the provided spanner wrench into one of the four tightening holes on the inner flange behind the blade.
    • Use the the provided nut wrench to loosen the hex nut while providing counterforce with the spanner wrench.
  7. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: passo 7, immagine 1 di 2 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: passo 7, immagine 2 di 2
    • Remove the hex nut.
    • Remove the outer flange.
  8. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: passo 8, immagine 1 di 2 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: passo 8, immagine 2 di 2
    • Remove the cutting blade.
    • The blade can be sharp, so handle with care.
  9. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Cutting Head: passo 9, immagine 1 di 3 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Cutting Head: passo 9, immagine 2 di 3 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Cutting Head: passo 9, immagine 3 di 3
    • Pull the entire cutting head straight off the shaft holding it in place.
Conclusione
Carsten Frauenheim
Membro da: 03/10/20
136.514 Reputazione
371 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.643 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 146
