Introduzione
The removal of the trigger is relatively challenging. It is the central part of the tool and has some wiring attached. Practice extreme caution and make sure the battery is removed.
Cosa ti serve
While pinching the red locking buttons, pull the battery away from the front of the drill until the battery is fully removed.
Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
Remove the two 40 mm Torx T10 screws near the bottom of the cover.
Lift the trigger assembly from the device. It is connected to the circuit board by wires.
Carefully desolder the wires off of the trigger assembly using a soldering iron on medium heat.
