Salta al contenuto principale
Milwaukee Hackzall 2625-20 Trigger Replacement
Cosa ti serve
  1. Milwaukee Hackzall 2625-20 Trigger Replacement, Trigger: passo 1, immagine 1 di 2 Milwaukee Hackzall 2625-20 Trigger Replacement, Trigger: passo 1, immagine 2 di 2
    • Use a T9 Torx screwdriver to remove the one 7.0 mm screw.
    • Use a T10 Torx screwdriver to remove the one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight 16.0 mm screws.
    • Remove the casing to reveal the internal components.
  2. Milwaukee Hackzall 2625-20 Trigger Replacement: passo 2, immagine 1 di 1
    • Use a soldering iron to desolder the connections on the back of the trigger assembly.
    • Practice caution while soldering. Ensure proper safety and soldering procedure is followed to avoid component damage and injury.
    • For more information on soldering, check out this guide.
  3. Milwaukee Hackzall 2625-20 Trigger Replacement: passo 3, immagine 1 di 2 Milwaukee Hackzall 2625-20 Trigger Replacement: passo 3, immagine 2 di 2
    • Remove the rest of the trigger assembly from the case.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,749
