Salta al contenuto principale
Milwaukee Hackzall 2625-20 Terminal Block Replacement
Cosa ti serve
  1. Milwaukee Hackzall 2625-20 Terminal Block Replacement, Outer Casing: passo 1, immagine 1 di 2 Milwaukee Hackzall 2625-20 Terminal Block Replacement, Outer Casing: passo 1, immagine 2 di 2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Terminal Block Replacement, Terminal Block: passo 2, immagine 1 di 1
    • Carefully remove the terminal block from the casing and note that there is a spring set into it.
  3. Milwaukee Hackzall 2625-20 Terminal Block Replacement: passo 3, immagine 1 di 2 Milwaukee Hackzall 2625-20 Terminal Block Replacement: passo 3, immagine 2 di 2
    • Use a soldering iron to melt any existing soldered attachments.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,485
