Salta al contenuto principale
Milwaukee Hackzall 2625-20 Motor Replacement
Cosa ti serve
  1. Milwaukee Hackzall 2625-20 Motor Replacement, Outer Casing: passo 1, immagine 1 di 2 Milwaukee Hackzall 2625-20 Motor Replacement, Outer Casing: passo 1, immagine 2 di 2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Motor Replacement, Electric Motor: passo 2, immagine 1 di 1
    • Find the red and black wire running from the back of the motor to the trigger mechanism.
    • With a soldering iron remove the two solders on the trigger mechanism.
  3. Milwaukee Hackzall 2625-20 Motor Replacement: passo 3, immagine 1 di 2 Milwaukee Hackzall 2625-20 Motor Replacement: passo 3, immagine 2 di 2
    • Remove the two screws connecting the motor to the gear box with a T15 torx screwdriver.
    • The motor is now free and can be removed from the tool.
Conclusione
2 Commenti
Is there any chance to change only brushes in this motor?
Marcin Kędzior - Replica
That’s my exact question as well, nobody seems to cover this..
Anthony DeSanto - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 37
Tutti i Tempi: 2,419
