Salta al contenuto principale
Mid F900 Motherboard Replacement
Cosa ti serve
  1. Mid F900 Motherboard Replacement, Back Cover: passo 1, immagine 1 di 1
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Motherboard Replacement: passo 2, immagine 1 di 2 Mid F900 Motherboard Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Motherboard Replacement, Motherboard: passo 3, immagine 1 di 2 Mid F900 Motherboard Replacement, Motherboard: passo 3, immagine 2 di 2
    • Using a +00 Phillips head screwdriver, remove the screws securing the motherboard to the device housing.
    • Screws are 4mm x 1mm in size.
  4. Mid F900 Motherboard Replacement: passo 4, immagine 1 di 2 Mid F900 Motherboard Replacement: passo 4, immagine 2 di 2
    • Desolder the two black and red wires connected to the motherboard.
    • Unclip and remove the ribbon cables attached to the motherboard.
    • For soldering help, use the How to Solder and Desolder Connections guide.
  5. Mid F900 Motherboard Replacement: passo 5, immagine 1 di 2 Mid F900 Motherboard Replacement: passo 5, immagine 2 di 2
    • Carefully lift and remove the motherboard from the device housing.
Conclusione
USF Tampa, Team 6-6, Remmell Fall 2016 Membro di USF Tampa, Team 6-6, Remmell Fall 2016
USFT-REMMELL-F16S6G6
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 301
