Salta al contenuto principale
Microsoft Surface Pro X Kickstand Replacement
Cosa ti serve
  1. Microsoft Surface Pro X Kickstand Replacement, Open the kickstand: passo 1, immagine 1 di 2 Microsoft Surface Pro X Kickstand Replacement, Open the kickstand: passo 1, immagine 2 di 2
    • Make sure your Surface Pro X is turned off, and laying screen-side down on a soft surface.
    • After turning off your device, make sure to remove the SSD from the Surface before starting any repairs. This will disconnect the battery and prevent damage to the device.
    • Lift the kickstand to at least a 90° angle, so that it is perpendicular to the Surface's screen. The further you open the hinge, the easier it is to access the SSD and SIM card door.
  2. Microsoft Surface Pro X Kickstand Replacement, Open the SSD and SIM card door: passo 2, immagine 1 di 2 Microsoft Surface Pro X Kickstand Replacement, Open the SSD and SIM card door: passo 2, immagine 2 di 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the bottom right corner of the SSD and SIM card door, located near the bottom right corner of the Surface.
    • Press firmly to open the door.
  3. Microsoft Surface Pro X Kickstand Replacement, Remove the SSD and SIM card door: passo 3, immagine 1 di 1
  4. Microsoft Surface Pro X Kickstand Replacement, Remove the SSD screw: passo 4, immagine 1 di 1
    • Use a T3 Torx screwdriver to remove the 2.4 mm screw securing the SSD.
  5. Microsoft Surface Pro X Kickstand Replacement, Remove the SSD: passo 5, immagine 1 di 3 Microsoft Surface Pro X Kickstand Replacement, Remove the SSD: passo 5, immagine 2 di 3 Microsoft Surface Pro X Kickstand Replacement, Remove the SSD: passo 5, immagine 3 di 3
    • Use your finger or a spudger to lift the SSD just enough that it clears the edges of its recess.
    • Don't lift the SSD more than you have to—doing so may damage the SSD or its socket.
    • Gently pull the SSD straight out of its socket.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  6. Microsoft Surface Pro X Kickstand Replacement, Place the Surface on your work surface: passo 6, immagine 1 di 1
    • Place your Surface screen-side down on your work surface.
  7. Microsoft Surface Pro X Kickstand Replacement, Lift the kickstand: passo 7, immagine 1 di 3 Microsoft Surface Pro X Kickstand Replacement, Lift the kickstand: passo 7, immagine 2 di 3 Microsoft Surface Pro X Kickstand Replacement, Lift the kickstand: passo 7, immagine 3 di 3
    • Lift the kickstand to about a 90° angle.
  8. Microsoft Surface Pro X Kickstand Replacement, Remove the kickstand hinge screws: passo 8, immagine 1 di 2 Microsoft Surface Pro X Kickstand Replacement, Remove the kickstand hinge screws: passo 8, immagine 2 di 2
    • Use a T3 Torx screwdriver to remove two 2.5 mm screws securing the kickstand to the kickstand hinges.
  9. Microsoft Surface Pro X Kickstand Replacement, Remove the kickstand: passo 9, immagine 1 di 2 Microsoft Surface Pro X Kickstand Replacement, Remove the kickstand: passo 9, immagine 2 di 2
    • Hold both hinges and the kickstand.
    • Move the kickstand down to a 45° angle.
  10. Microsoft Surface Pro X Kickstand Replacement: passo 10, immagine 1 di 3 Microsoft Surface Pro X Kickstand Replacement: passo 10, immagine 2 di 3 Microsoft Surface Pro X Kickstand Replacement: passo 10, immagine 3 di 3
    • Hold the kickstand by the center of its bottom edge.
    • Move the kickstand up by about 10° to detach the kickstand's screw bosses from the hinges.
    • During reassembly, make sure the hinges are fully inserted into their recesses in the kickstand. Follow the instructions in the next step to reinsert the hinges.
  11. Microsoft Surface Pro X Kickstand Replacement, Hinge reassembly information: passo 11, immagine 1 di 3 Microsoft Surface Pro X Kickstand Replacement, Hinge reassembly information: passo 11, immagine 2 di 3 Microsoft Surface Pro X Kickstand Replacement, Hinge reassembly information: passo 11, immagine 3 di 3
    • During reassembly, follow these steps to make sure the hinges are fully inserted into their kickstand recesses:
    • Tilt the bottom edge of the kickstand toward the hinges.
    • Insert the hinges into the kickstand recesses.
    • Check to see if the faces of the hinges are flush with the underside of the kickstand.
  12. Microsoft Surface Pro X Kickstand Replacement: passo 12, immagine 1 di 2 Microsoft Surface Pro X Kickstand Replacement: passo 12, immagine 2 di 2
    • There are two adhesive tabs securing the kickstand to the frame. You'll need to pull them out with a strong and steady force.
    • The two adhesive tabs are located in the middle of the kickstand edge closest to the frame.
  13. Microsoft Surface Pro X Kickstand Replacement: passo 13, immagine 1 di 3 Microsoft Surface Pro X Kickstand Replacement: passo 13, immagine 2 di 3 Microsoft Surface Pro X Kickstand Replacement: passo 13, immagine 3 di 3
    • Pull slowly to avoid tearing the two adhesive tabs.
    • While holding the Surface with one hand, pull the kickstand out of the frame.
    • Be sure to insert the tabs when installing the new kickstand before replacing the screws.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Microsoft Surface Pro X Answers community for help.
Kyle Smith
Membro da: 02/01/21
49.220 Reputazione
123 Guide realizzate
3Commenti sulla guida
How do I order the 2.5 mm screws holding kickstand on. Mine are missing.
kaption93 - Replica
The hinge replacement guide is vague, there should be one that's more specific. It'd be cool if you gave a link to the kickstand replacement in case the kickstand screw taps are stripped or unusable (sheered screw half in hole).
Otherwise, I thank you for what you do, much appreciated..
Joe M - Replica
Where can the replacement kickstand be purchased?
DMos - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 78
Tutti i Tempi: 2,582
