Salta al contenuto principale
Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement
Cosa ti serve
  1. Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Prepare your laptop for disassembly: passo 1, immagine 1 di 2 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Prepare your laptop for disassembly: passo 1, immagine 2 di 2
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Flip your laptop over: passo 2, immagine 1 di 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Flip your laptop over: passo 2, immagine 2 di 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Flip your laptop over: passo 2, immagine 3 di 3
    • Close your laptop and lay it down so the rubber feet are facing up.
  3. Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the feet: passo 3, immagine 1 di 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the feet: passo 3, immagine 2 di 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the feet: passo 3, immagine 3 di 3
    • Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
    • You can also use the point of a spudger. However, you're more likely to damage the foot, if you're reusing it.
    • Use your tweezers to pry up and remove the foot.
    • The feet may eject very quickly—be careful not to lose them.
    • Repeat the process to remove the remaining feet.
    • To install a foot, align the pegs on the bottom with their cutouts in the frame and press the foot into place.
  4. Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the lower case screws: passo 4, immagine 1 di 2 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the lower case screws: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    FixMat
    $31.41
    • While the Surface Laptop 7 uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
  5. Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Detach the lower case: passo 5, immagine 1 di 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Detach the lower case: passo 5, immagine 2 di 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Detach the lower case: passo 5, immagine 3 di 3
    • Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
    • Don't insert the pick near the outer edges or you'll damage the antenna bar.
  6. Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement: passo 6, immagine 1 di 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement: passo 6, immagine 2 di 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement: passo 6, immagine 3 di 3
    • Twist the pick to lift the lower case enough that you can grip it with your hand.
  7. Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the lower case: passo 7, immagine 1 di 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the lower case: passo 7, immagine 2 di 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the lower case: passo 7, immagine 3 di 3
    • Lift the lower case and remove it.
Conclusione
Spencer Day
Membro da: 09/14/22
149.525 Reputazione
995 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.623 Guide realizzate
3Commenti sulla guida
where can i purchase 4 spare screws for the bottom of this laptop?
Brian - Replica
I would like to know the same thing. I'v lost one of my screws off my Surface laptop 7. Does anyone know what size screw is needed?
David Glaze - Replica
i got same problem and need these 4 spare screws
Adel Kazemirad - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 81
Tutti i Tempi: 1,102
