Salta al contenuto principale
Microsoft Surface Headphones Speaker Replacement
Cosa ti serve
  1. Microsoft Surface Headphones Speaker Replacement, Ear Cushion: passo 1, immagine 1 di 1
    • Firmly grasp the ear cushions, and rotate them counterclockwise about 45 degrees, or until you hear a "click."
    • Be careful not to use excessive force during rotation.
  2. Microsoft Surface Headphones Speaker Replacement: passo 2, immagine 1 di 1
    • Lift the ear cushions off the speaker housings.
  3. Microsoft Surface Headphones Speaker Replacement, Speaker: passo 3, immagine 1 di 2 Microsoft Surface Headphones Speaker Replacement, Speaker: passo 3, immagine 2 di 2
    • Remove the six 2.6mm screws with a Phillips #00 screwdriver, and gently lift the speaker housings away.
    • If only one of the speakers is malfunctioning, only remove the screws on the affected side, and leave the functional speaker intact.
  4. Microsoft Surface Headphones Speaker Replacement: passo 4, immagine 1 di 2 Microsoft Surface Headphones Speaker Replacement: passo 4, immagine 2 di 2
    • Gently pry the speaker housing away from the chassis with a spudger.
  5. Microsoft Surface Headphones Speaker Replacement: passo 5, immagine 1 di 1
    • Desolder the speaker's motherboard connections.
    • Desoldering and soldering are delicate procedures, and there is a potential for device damage.
Conclusione
Altre 2 persone hanno completato questa guida.
6 Commenti
How can I get my turtle Beach to pair
Miguel Garcia - Replica
How do I remove the speaker from the plastic housing? Is it glued in place? I desoldered the speaker unit and now I am trying to take out speaker from its housing.
Stephen Hyland - Replica
I would also like to know this! replacing the speaker requires the plastic housing to be opened. I tried heating the housing with a hair dryer but no result....
fixer8888 -
I cut it in half down the side. Very long a tedious process. also makes it hard to get a tight seal for reassembly but with a little more patience than I had and a clamp to glue the pieces together could probably get a nice finish. I have a gap which causes a little weirdness for the ANC especially with wind.
joshray -
Where do you get replacement speaker
marilyn - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 64
Tutti i Tempi: 1,918
