Salta al contenuto principale
Microsoft Surface Headphones Motherboard Replacement
Cosa ti serve
  1. Microsoft Surface Headphones Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Microsoft Surface Headphones Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Firmly grasp the ear cushions and rotate them counterclockwise, about 45 degrees, until you hear a "click."
    • To replace the motherboard, you only need to remove the right cushion, labeled with an "R" on the headband.
  2. Microsoft Surface Headphones Motherboard Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the three 2.6 mm screws securing the right speaker housing to the chassis.
  3. Microsoft Surface Headphones Motherboard Replacement: passo 3, immagine 1 di 1
    • Lift the speaker housing away from the chassis, taking care not to damage the motherboard connections.
    • Desolder the two speaker motherboard connections.
    • Desoldering and soldering are delicate procedures, and there is a potential for device damage.
  4. Microsoft Surface Headphones Motherboard Replacement: passo 4, immagine 1 di 1
    • Desolder the red and black speaker connections.
  5. Microsoft Surface Headphones Motherboard Replacement: passo 5, immagine 1 di 1
    • Desolder the 23 connections from the motherboard.
    • Before soldering the connections to your new motherboard, be sure to pay close attention to which wire goes where; they're very easy to mix up.
  6. Microsoft Surface Headphones Motherboard Replacement: passo 6, immagine 1 di 1
    • Use a Torx screwdriver to remove the four screws.
    • Lift the motherboard up and out of the chassis.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,043
