Introduzione
Use this guide to replace the GPU board in a Microsoft Surface Book.
The GPU board is home to an Nvidia N16S-LG custom GeForce GPU with 1 GB of VRAM. This is the major connections component of the keyboard; it hooks everything together and makes it all work. This guide will require the removal of the SD card slot and USB ports. Make sure you have a place to store all the tiny screws you will be removing.
Cosa ti serve
Press and hold the Detach button on the keyboard.
Alternatively, click the Detach icon on the right-hand side of the Windows 10 taskbar.
Remove the display.
Flip open the display as far as it will go.
Lift the device up and place it on its side, with the display facing away from you and the SurfaceConnect port facing up.
Insert the straight end of the paper clip at a 45 degree angle into the sixth hole from the left.
Firmly push the paper clip into the hole.
Pull the base away from the display to detach it.
With one side detached, pull firmly to pivot the display out to disconnect the second side.
Orient your keyboard with the internals facing up and the USB ports on the right.
Remove the larger, black ribbon cable located on the USB card with a plastic opening tool by lifting the tab away from its connector. Again, place the tool underneath the tab and pry it off.
Altre 4 persone hanno completato questa guida.
3Commenti sulla guida
Where can I buy a replacement gpu board?
where can l find A Replacement gpu board?
