Introduzione
This guide is used to explain how to replace the rear camera on the Microsoft Surface Book 2 15. It uses the motherboard replacement guide as a prerequisite guide, which is a difficult task to perform.
The rear camera replacement itself is a fairly simple one, that just requires detaching a ribbon cable and reattaching it. However, the steps before it where you open the laptop can difficult.
A majority of the issues that are found with the Microsoft Surface Book 2 15 can be solved through software solutions. Therefore make sure to review troubleshooting page and trying the solutions listed their before making any repairs to the device.
Cosa ti serve
Open the laptop, then orient it towards yourself.
Count from the bottom up by six holes on the tablet portion of the laptop.
After lifting the motherboard, locate the two cameras near the center of the motherboard.
Unplug front camera (right side) from the motherboard (lift carefully).
In the top left-hand corner of the tablet is where the camera sits.
Unscrew the T3 torx screw.
