Salta al contenuto principale
Microsoft Surface Book 2 15" Headphone Jack Replacement
Cosa ti serve
  1. Microsoft Surface Book 2 15" Headphone Jack Replacement, Motherboard: passo 1, immagine 1 di 1
    • Open the laptop, then orient it so the touchpad is on your left.
    • Starting at the hinge, count six holes up on the tablet portion of the laptop.
  2. Microsoft Surface Book 2 15" Headphone Jack Replacement: passo 2, immagine 1 di 2 Microsoft Surface Book 2 15" Headphone Jack Replacement: passo 2, immagine 2 di 2
    • Take a paper clip and unfold it.
    • Place the paperclip in the sixth hole and push until you hear a click.
    • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
    • After the right side has been detached, lift up the left side as well.
  3. Microsoft Surface Book 2 15" Headphone Jack Replacement: passo 3, immagine 1 di 1
    • Place the tablet on a flat surface.
    • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
  4. Microsoft Surface Book 2 15" Headphone Jack Replacement: passo 4, immagine 1 di 1
    • Using a plastic pick, slice underneath the edge of the screen.
    • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
    • Take care not to insert the tool too far to avoid cutting the ribbon cables.
    • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
    • Don't use a metal tool, that could damage the screen or internal parts.
  5. Microsoft Surface Book 2 15" Headphone Jack Replacement: passo 5, immagine 1 di 2 Microsoft Surface Book 2 15" Headphone Jack Replacement: passo 5, immagine 2 di 2
    • Lift up the screen.
    • Detach the ribbon cables connecting the underside of the screen to the motherboard.
  6. Microsoft Surface Book 2 15" Headphone Jack Replacement: passo 6, immagine 1 di 2 Microsoft Surface Book 2 15" Headphone Jack Replacement: passo 6, immagine 2 di 2
    • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
    • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
  7. Microsoft Surface Book 2 15" Headphone Jack Replacement: passo 7, immagine 1 di 1
    • Once the screws are removed from the top bar, gently lift up and remove it.
    • Be careful not to damage any ribbon cables or wires.
    • Gently lift up on the motherboard to remove it.
  8. Microsoft Surface Book 2 15" Headphone Jack Replacement, Headphone Jack: passo 8, immagine 1 di 2 Microsoft Surface Book 2 15" Headphone Jack Replacement, Headphone Jack: passo 8, immagine 2 di 2
    • Gently pull the headphone jack out of the slot.
  9. Microsoft Surface Book 2 15" Headphone Jack Replacement: passo 9, immagine 1 di 2 Microsoft Surface Book 2 15" Headphone Jack Replacement: passo 9, immagine 2 di 2
    • On the motherboard, unplug the ribbon cable connecting the headphone jack to the motherboard.
    • Flip up the latch on the connector and then pull out the cable.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 22
Tutti i Tempi: 159
