Salta al contenuto principale
MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement
Cosa ti serve
  1. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement, Remove the recoil starter bolts: passo 1, immagine 1 di 1
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Use a 10 mm socket to remove the three 24 mm long bolts.
  2. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement, Remove the recoil starter assembly: passo 2, immagine 1 di 1
    • Remove the recoil starter assembly.
  3. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement: passo 3, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement: passo 3, immagine 2 di 2
    • If you are replacing the assembly with a non-OEM part, you may also have to replace the starter cap.
    • Remove the 3/4" bolt with a deep socket.
    • This bolt can be very difficult to remove. Use the hook as a bracing point to keep the starter cap from rotating.
Conclusione
Arthur Shi
Membro da: 01/03/18
252.816 Reputazione
526 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 675
