Salta al contenuto principale
Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement
Cosa ti serve
  1. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Safety precautions: passo 1, immagine 1 di 2 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Safety precautions: passo 1, immagine 2 di 2
    • Power off the machine at least one hour prior to starting repairs. Ensure the machine is completely cool to the touch.
    • Flip the power switch into the OFF position.
    • Unplug any extension cords from the included power cord.
  2. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Remove the right-side cover: passo 2, immagine 1 di 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
  3. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: passo 3, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: passo 3, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: passo 3, immagine 3 di 3
    • Tilt the right-side cover down to access the PCB board.
    • Do not fully remove the right-side cover, it is still attached via the on/off switch.
    • During reassembly, ensure the display window is aligned with the LCD display.
  4. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Disconnect all wires from the PCB: passo 4, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Disconnect all wires from the PCB: passo 4, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Disconnect all wires from the PCB: passo 4, immagine 3 di 3
    • Disconnect all wires from the main PCB assembly:
    • The photocell wire connector labeled CN3 on the board
    • The white wire connector labeled CN2 on the board
    • The orange wire labeled MOTOR1 on the board
    • The igniter wire connector labeled CN1 on the board
    • The yellow wire labeled ACIN1 Yellow on the board
    • The white wire labeled ACIN2 White on the board
    • The red wire labeled MOTOR2 Red on the board.
  5. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Remove the main PCB assembly: passo 5, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Remove the main PCB assembly: passo 5, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Remove the main PCB assembly: passo 5, immagine 3 di 3
    • Use a pair of pliers to depress the locking tabs on one of the corner retaining clips securing the PCB to the bracket.
    • With the locking tabs depressed, pull the PCB away from the bracket to remove the corner.
    • Repeat for the three remaining retaining clips.
  6. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: passo 6, immagine 1 di 2 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: passo 6, immagine 2 di 2
    • Remove the main PCB assembly.
Conclusione
Sam Omiotek
Membro da: 02/25/19
84.442 Reputazione
290 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 142
