Introduzione
Follow this guide to replace the ignitor on a Mi-T-M heater model MH-0190-0M10.
After the pump and motor are reinstalled, use a flat blade screwdriver to adjust the pump pressure to 7.5 PSI as instructed on page 17 of the user manual.
Cosa ti serve
Flip the power switch into the OFF position.
Unplug any extension cords from the included power cord.
Use a 5/16Â inch socket or Phillips screwdriver to remove the eight screws securing the upper shell, four on each side.
Use a 5/16Â inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
Use a 5/16Â inch socket or Phillips screwdriver to remove the screw securing the two green ground wires to the frame.
Use a pair of needle nose pliers to release the hose clamp from the fuel line.
Slide the hose clamp off of the nipple, about one inch down the fuel line.
Use a pair of needle nose pliers to disconnect the wires connecting the motor and pump assembly to the main PCB board:
One red cable labeled MOTOR 2 on the main PCB board
One orange cable labeled MOTOR 1 on the main PCB board
Use a Phillips screwdriver to remove the screw securing the capacitor band clamp.
Feed the orange and red wires out through the opening in the lower shell.
Grab the spark plug wires by their boots and pull firmly to disconnect them from the spark plug.
Use a pair of needle nose pliers to depress the locking tab on the red wiring harness's connector labeled IG on the main PCB assembly.
With the locking tab depressed, pull to remove the red wire from its header on the PCB.
Use your fingers to bend the metal tab on the lower shell holding the igniter in place upward to create space for the igniter to be removed.
