Salta al contenuto principale
Mi-T-M Heater MH-0190-0M10 Ignitor Replacement
Cosa ti serve
  1. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Safety precautions: passo 1, immagine 1 di 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Safety precautions: passo 1, immagine 2 di 2
    • Power off the machine at least one hour prior to starting repairs. Ensure the machine is completely cool to the touch.
    • Flip the power switch into the OFF position.
    • Unplug any extension cords from the included power cord.
  2. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the upper shell: passo 2, immagine 1 di 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the upper shell: passo 2, immagine 2 di 2
    • Use a 5/16 inch socket or Phillips screwdriver to remove the eight screws securing the upper shell, four on each side.
  3. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 3, immagine 1 di 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 3, immagine 2 di 2
    • Lift the upper shell straight up off of the machine to remove it.
  4. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the right-side cover: passo 4, immagine 1 di 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
  5. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 5, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 5, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 5, immagine 3 di 3
    • Tilt the right-side cover down to access the PCB board.
    • Do not fully remove the right-side cover, it is still attached via the on/off switch.
    • During reassembly, ensure the display window is aligned with the LCD display before you press the cover into place.
  6. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 6, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 6, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 6, immagine 3 di 3
    • There are two wires connecting the power switch to the main PCB assembly.
    • Use needle nose pliers to remove the wire with the blue connector.
    • Remove the wire with the clear connector.
    • Remove the right-side cover.
    • During reassembly, install the power switch wires back in their original locations with the blue wire above the clear wire.
  7. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the ground wires: passo 7, immagine 1 di 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the screw securing the two green ground wires to the frame.
  8. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the fuel line: passo 8, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the fuel line: passo 8, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the fuel line: passo 8, immagine 3 di 3
    • Use a pair of needle nose pliers to release the hose clamp from the fuel line.
    • Slide the hose clamp off of the nipple, about one inch down the fuel line.
  9. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 9, immagine 1 di 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 9, immagine 2 di 2
    • Pull to disconnect the fuel line from the motor and pump assembly.
  10. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 10, immagine 1 di 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 10, immagine 2 di 2
    • Use a pair of needle nose pliers to remove the fuel line hose clamp.
  11. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the motor and pump assembly: passo 11, immagine 1 di 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the motor and pump assembly: passo 11, immagine 2 di 2
    • Use a pair of needle nose pliers to disconnect the wires connecting the motor and pump assembly to the main PCB board:
    • One red cable labeled MOTOR 2 on the main PCB board
    • One orange cable labeled MOTOR 1 on the main PCB board
    • Pull the wires with the needle nose pliers by their connectors and not the wires themselves.
  12. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 12, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 12, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 12, immagine 3 di 3
    • Use a pair of flush cutters to cut the cable tie harnessing the wires running from the main PCB assembly.
    • Remove the cable tie.
    • During reassembly, install a new cable tie.
  13. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 13, immagine 1 di 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 13, immagine 2 di 2
    • Use a pair of flush cutters to cut the cable tie harnessing the orange, red, white, and black wires near the fuel line.
  14. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 14, immagine 1 di 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 14, immagine 2 di 2
    • Use a pair of flush cutters to cut the cable tie harnessing the orange and red wires next to the motor.
  15. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Detach the capacitor: passo 15, immagine 1 di 1
    • Use a Phillips screwdriver to remove the screw securing the capacitor band clamp.
  16. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 16, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 16, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 16, immagine 3 di 3
    • Remove the capacitor from the band clamp.
    • During reassembly, realign the foam padding between the capacitor and the band clamp.
  17. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the motor and pump assembly: passo 17, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the motor and pump assembly: passo 17, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the motor and pump assembly: passo 17, immagine 3 di 3
    • Feed the orange and red wires out through the opening in the lower shell.
  18. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 18, immagine 1 di 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the left-side cover.
  19. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 19, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 19, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 19, immagine 3 di 3
    • Remove the left-side cover.
  20. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 20, immagine 1 di 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 20, immagine 2 di 2
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four screws securing the motor mount bracket, two on each side.
  21. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 21, immagine 1 di 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 21, immagine 2 di 2
    • Lift the motor, pump, and bracket assembly straight up out of the machine.
  22. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the spark plug wires: passo 22, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the spark plug wires: passo 22, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the spark plug wires: passo 22, immagine 3 di 3
    • Grab the spark plug wires by their boots and pull firmly to disconnect them from the spark plug.
  23. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 23, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 23, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 23, immagine 3 di 3
    • Feed the wires through the opening in the lower shell.
  24. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the ignitor from the main PCB assembly: passo 24, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the ignitor from the main PCB assembly: passo 24, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the ignitor from the main PCB assembly: passo 24, immagine 3 di 3
    • Use a pair of needle nose pliers to depress the locking tab on the red wiring harness's connector labeled IG on the main PCB assembly.
    • With the locking tab depressed, pull to remove the red wire from its header on the PCB.
  25. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the igniter: passo 25, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the igniter: passo 25, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the igniter: passo 25, immagine 3 di 3
    • Use your fingers to bend the metal tab on the lower shell holding the igniter in place upward to create space for the igniter to be removed.
    • During reassembly, bend the tab back into place once the new igniter is installed.
  26. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 26, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 26, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 26, immagine 3 di 3
    • Lift the igniter out from underneath the lower shell.
  27. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 27, immagine 1 di 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 27, immagine 2 di 2
    • Feed the red wire harness through the opening in the lower shell.
  28. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 28, immagine 1 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 28, immagine 2 di 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: passo 28, immagine 3 di 3
    • Remove the spark plug wires from underneath the lower shell.
    • Remove the igniter.
Conclusione
Sam Omiotek
Membro da: 02/25/19
84.575 Reputazione
290 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 264
