Salta al contenuto principale
MerchSource the Black Series Boat Racer Battery Cable Replacement
Cosa ti serve
  1. MerchSource the Black Series Boat Racer Battery Cable Replacement, Battery Cable: passo 1, immagine 1 di 2 MerchSource the Black Series Boat Racer Battery Cable Replacement, Battery Cable: passo 1, immagine 2 di 2
    • Turn the remote controller over to the back.
  2. MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 2, immagine 1 di 1
    • Slide the battery cover off.
  3. MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 3, immagine 1 di 2 MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 3, immagine 2 di 2
    • Remove both AA-batteries.
  4. MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #1 screwdriver, remove the four screws located in the four corners of the back of the remote controller.
    • Screw length is 6 mm.
  5. MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 5, immagine 1 di 3 MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 5, immagine 2 di 3 MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 5, immagine 3 di 3
    • Separate the two halves of the remote controller.
  6. MerchSource the Black Series Boat Racer Battery Cable Replacement: passo 6, immagine 1 di 1
    • Solder the wire to reconnect it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 206
