Salta al contenuto principale
Memorex CD Alarm Clock Radio Antenna Replacement
Cosa ti serve
  1. Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: passo 1, immagine 1 di 3 Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: passo 1, immagine 2 di 3 Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: passo 1, immagine 3 di 3
    • Turn the clock radio over so the bottom is facing up.
    • Pull the tab upward and remove the cover from the battery compartment.
    • Remove the batteries.
  2. Memorex CD Alarm Clock Radio Antenna Replacement: passo 2, immagine 1 di 3 Memorex CD Alarm Clock Radio Antenna Replacement: passo 2, immagine 2 di 3 Memorex CD Alarm Clock Radio Antenna Replacement: passo 2, immagine 3 di 3
    • Remove the five screws on the bottom of the device with a screwdriver.
    • Grasp the top and bottom and gently pull apart.
  3. Memorex CD Alarm Clock Radio Antenna Replacement, Antenna: passo 3, immagine 1 di 1
    • Locate the small silver transistor between the front left speaker and the tuning knob. The antenna should be attached directly below the transistor.
    • Deolder the antenna wire from the circuit board, and remove the wire.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 964
