Salta al contenuto principale
Mattel Loopz Speaker Replacement
Cosa ti serve
  1. Mattel Loopz Speaker Replacement, Batteries: passo 1, immagine 1 di 1
    • Use a No. 2 Phillips head screwdriver to take out the 1/4" screw that holds the battery cover in place on the bottom of the device.
  2. Mattel Loopz Speaker Replacement: passo 2, immagine 1 di 1
    • Take out the 4 AA Batteries.
  3. Mattel Loopz Speaker Replacement, Speaker: passo 3, immagine 1 di 1
    • Remove red screw covers (13 total) using spudger.
  4. Mattel Loopz Speaker Replacement: passo 4, immagine 1 di 1
    • Remove the thirteen 12.7mm screws with a #1 Phillips screwdriver.
  5. Mattel Loopz Speaker Replacement: passo 5, immagine 1 di 1
    • Remove 6 white caps using spudger to reveal screws underneath.
  6. Mattel Loopz Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the six 16mm screws with a #1 Phillips screwdriver.
  7. Mattel Loopz Speaker Replacement: passo 7, immagine 1 di 1
    • Remove the white cover. Be sure to remove the front and the back.
  8. Mattel Loopz Speaker Replacement: passo 8, immagine 1 di 1
    • Remove the black, plastic cover to reveal the internal electronics as shown.
  9. Mattel Loopz Speaker Replacement: passo 9, immagine 1 di 1
    • Remove the two 6.4mm screws with a #1 Phillips screwdriver.
  10. Mattel Loopz Speaker Replacement: passo 10, immagine 1 di 1
    • Remove the speaker as shown.
  11. Mattel Loopz Speaker Replacement: passo 11, immagine 1 di 1
    • Use a soldering iron to desolder the red and black speaker wires from the speaker.
Conclusione
IUPUI, Team S1-G2, Freund Spring 2018 Membro di IUPUI, Team S1-G2, Freund Spring 2018
IUPUI-FREUND-S18S1G2
3 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 645
