Salta al contenuto principale
Master and Dynamic MW50 Motherboard Replacement
Cosa ti serve
  1. Master and Dynamic MW50 Motherboard Replacement, Master and Dynamic MW50 Disassembly: passo 1, immagine 1 di 3 Master and Dynamic MW50 Motherboard Replacement, Master and Dynamic MW50 Disassembly: passo 1, immagine 2 di 3 Master and Dynamic MW50 Motherboard Replacement, Master and Dynamic MW50 Disassembly: passo 1, immagine 3 di 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Motherboard Replacement: passo 3, immagine 1 di 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Motherboard Replacement, Motherboard: passo 4, immagine 1 di 3 Master and Dynamic MW50 Motherboard Replacement, Motherboard: passo 4, immagine 2 di 3 Master and Dynamic MW50 Motherboard Replacement, Motherboard: passo 4, immagine 3 di 3
    • Remove the 2mm screw holding the side cover plate in place with a JIS #00 screwdriver.
    • Move the side cover off to the side.
    • The black cable connected to the motherboard from the side cover can be gently pulled off from the motherboard side. It isn't soldered on.
  5. Master and Dynamic MW50 Motherboard Replacement: passo 5, immagine 1 di 1
    • Desolder all the wires connected to the motherboard.
    • Refer to this picture for soldering the wires on the new motherboard.
  6. Master and Dynamic MW50 Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the two 2mm screws holding the motherboard in place.
  7. Master and Dynamic MW50 Motherboard Replacement: passo 7, immagine 1 di 1
    • Replace with new motherboard.
Conclusione
To reassemble your device, follow these instructions in reverse order. You may want to use the picture from Step 5 to correctly re-solder your device.
Ryan Chan
Membro da: 01/24/19
297 Reputazione
2 Guide realizzate
Cal Poly, Team S1-G4, White Winter 2019 Membro di Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 369
