Salta al contenuto principale
Master and Dynamic MW50 Battery Replacement
Cosa ti serve
  1. Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: passo 1, immagine 1 di 3 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: passo 1, immagine 2 di 3 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: passo 1, immagine 3 di 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Battery Replacement: passo 2, immagine 1 di 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Battery Replacement: passo 3, immagine 1 di 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Battery Replacement, Battery: passo 4, immagine 1 di 2 Master and Dynamic MW50 Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Remove the tape attaching the thicker white wire to the battery. You may consider keeping the tape to reattach the wire later.
  5. Master and Dynamic MW50 Battery Replacement: passo 5, immagine 1 di 1
    • Desolder the two wires circled here.
  6. Master and Dynamic MW50 Battery Replacement: passo 6, immagine 1 di 2 Master and Dynamic MW50 Battery Replacement: passo 6, immagine 2 di 2
    • Use an iFixit opening tool or something similar to pry out the battery.
    • There are two small tabs circled here that are holding the battery in. Push these down while prying to make the battery come out easier.
    Where to get the replacement battery?
    Jon Allen McCarty - Replica
Conclusione
Tyler Guffey
Membro da: 01/24/19
208 Reputazione
2 Guide realizzate
Cal Poly, Team S1-G4, White Winter 2019 Membro di Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Membri
12 Guide realizzate
Un commento
Hi, do you know where it’s possible to buy replacement batteries??
Mike - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,736
