Introduzione
This guide will allow you to disassemble your Martian Victory Smart Watch in order to replace the Analog Watch Face.
Cosa ti serve
Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
Locate the ribbon connection, and use remove the clips holding the strip on each side using needle tool.
Quasi finito!
Conclusione
