Salta al contenuto principale
Maquet Servo-U O2 Supply Replacement
  1. Maquet Servo-U O2 Supply Replacement, O2 Supply: passo 1, immagine 1 di 1
    • Turn the inspiratory channel lock one quarter of a turn to release.
    • Lift off the inspiratory channel cover.
    • WARNING! The inspiratory channel cover shall be kept in place once maintenance has been performed. Otherwise the gas modules can be affected and deliver the wrong flow.
  2. Maquet Servo-U O2 Supply Replacement: passo 2, immagine 1 di 1
    • Lower the locking catch.
  3. Maquet Servo-U O2 Supply Replacement: passo 3, immagine 1 di 2 Maquet Servo-U O2 Supply Replacement: passo 3, immagine 2 di 2
    • Disconnect the O2 cell connector.
    • Lift and discard the O2 cell with the rubber seal to special waste and/or remove and discard the bacterial filter to hazardous waste.
  4. Maquet Servo-U O2 Supply Replacement: passo 4, immagine 1 di 1
    • Ensure that the new rubber seal is intact, then firmly put in a new bacterial filter.
  5. Maquet Servo-U O2 Supply Replacement: passo 5, immagine 1 di 1
    • Connect the O2 cell connector.
    • Put the O2 cell in position.
    • Close the locking catch.
  6. Maquet Servo-U O2 Supply Replacement: passo 6, immagine 1 di 1
    • Put the inspiratory channel cover in position.
    • Tighten the inspiratory channel lock.
    • Perform a pre-use check stated in Troubleshooting Page.
Linea Traguardo
Cal Poly, Team S7-G2, Paton Spring 2020 Membro di Cal Poly, Team S7-G2, Paton Spring 2020
CPSU-PATON-S20S7G2
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 37
Tutti i Tempi: 2,112
