Salta al contenuto principale
Magic Bullet NutriBullet Pro Rubber Gasket Replacement
Cosa ti serve
  1. Magic Bullet NutriBullet Pro Rubber Gasket Replacement, Rubber Gasket: passo 1, immagine 1 di 1
    • Unscrew the blending blade lid from the cup.
  2. Magic Bullet NutriBullet Pro Rubber Gasket Replacement: passo 2, immagine 1 di 1
    • Use tweezers to peel back the rubber gasket that surrounds the inner ring of the lid.
    Now what?
    bthull@rogers.com
    Brian - Replica
    What is step three…
    bthull@rogers.com
    Brian - Replica
    Is the gasket supposed to be loose or glued in place?
    Brian - Replica
    His Step 3 is to "Reverse the process" which is NOT helpful at all. I think I would need about 4 hands to keep the gasket in the groove while turning the base to complete the circle. This was not usefull!
    Jon Findley - Replica
Conclusione
Andrew Pana
Membro da: 10/03/16
173 Reputazione
1 Guida realizzata
Cal Poly, Team 18-4, Forte Fall 2016 Membro di Cal Poly, Team 18-4, Forte Fall 2016
CPSU-FORTE-F16S18G4
4 Membri
4 Guide realizzate
2 Commenti
AWESOME! No more leaks. Such an easy fix. Thank you
campwallaby - Replica
thanks but how do you get the new gasket back on????????
jano3 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 38
Tutti i Tempi: 3,939
