Salta al contenuto principale
Magellan RoadMate 5250T-LM Motherboard Replacement
Cosa ti serve
  1. Magellan RoadMate 5250T-LM Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Magellan RoadMate 5250T-LM Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Remove all four 5mm screws from the back of the device using a Phillips Head screwdriver size 000.
  2. Magellan RoadMate 5250T-LM Motherboard Replacement: passo 2, immagine 1 di 2 Magellan RoadMate 5250T-LM Motherboard Replacement: passo 2, immagine 2 di 2
    • Open the casing of the device using a plastic spudger.
  3. Magellan RoadMate 5250T-LM Motherboard Replacement: passo 3, immagine 1 di 2 Magellan RoadMate 5250T-LM Motherboard Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the tape covering the display connector on top of the motherboard.
    • Use a nylon spudger to flip up the black tab on the ZIF connector.
    • Pull the ribbon cable out with tweezers.
    • The ribbon cable may fall out once the tape is removed.
  4. Magellan RoadMate 5250T-LM Motherboard Replacement: passo 4, immagine 1 di 2 Magellan RoadMate 5250T-LM Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the motherboard from the device by unscrewing all three 4mm screws that are connecting it to the casing with a Phillips Head screwdriver size 000.
  5. Magellan RoadMate 5250T-LM Motherboard Replacement: passo 5, immagine 1 di 1
    • Disconnect the original battery from the motherboard and the speaker by desoldering all five wires that attach them to the motherboard.
    • Click here to visit iFixIt's guide on soldering.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 318
