Introduzione
It is recommended to have had some experience soldering before attempting this replacement.
Cosa ti serve
Place the device face down on a flat surface.
Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
Use tweezers to disconnect the ZIF connector from the motherboard.
Lay the back panel on a flat surface with the battery, motherboard, and speaker facing up.
Use a plastic opening tool to gently pull the battery away from the back panel in order to remove the adhesive that helps the battery stick to the panel.
Using the soldering iron, carefully desolder the two wires connected to the speaker.
The motherboard should now be separated from both the battery and the speaker.
Un commento
Is the hard drive solded to the motherboard as a chip? Do someone have the pinout/things-in-the-diagram of the mother board?
