Strumenti
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
Pull the optical drive cable away from the optical drive.
Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
Altre 122 persone hanno completato questa guida.
10 Commenti
I am confused - per Apple's specs, this model doesn't have an optical drive: https://support.apple.com/kb/sp649?local...
Yes, the specs say so:
Connections and Expansion
MagSafe power port
Gigabit Ethernet port
FireWire 800 port (up to 800 Mbps)
Two USB 3 ports (up to 5 Gbps)
Thunderbolt port (up to 10 Gbps)
Headphone port
SDXC card slot
Kensington lock slot
8x SuperDrive <-
That would be the retina mid 2012, this guide only applies to the unibody mid 2012 macbook pro
Ethan -
Am I the only one who finds this ‘guide’ to me inappropriately titled. I mean, it should be called ‘optical drive removal and that’s it’. The title it currently has led me to believe that it would not only show how to take out the optical drive, but that it would then show me how to put in the new hard drive I have. In other words, where’s the rest? That nobody else has posted this comment is making me equally crazy right now. It’s got me so crazy right. This guides got me feeling so crazy right now. Got me so crazy, this guides got me crazy, this guides got me crazy. This Guide!!!!
Are you trying to take the optical drive out entirely and install a new HDD there? You need an HDD bay (mounter, adapter, whatever you call it) for your new drive to install it because: 1. HDD is way too small to fit the place and 2. the connector for optical drive is different from that of your HDD’s.
If you don’t have any, iFixit offers this (careful, it supports HDD up to only 750GB!)
If you have one, did yours come with some instruction to secure your HDD in place? Follow the instruction on that (usually requires you to put 4 screws on the side of your HDD as well as to screw the metal part you scavenged from your SuperDrive.) Once you take out the SuperDrive, replace the words “optical drive” in this guide with “your HDD bay,” then backtrack the guide (in fact, most of the guides here only instruct you how to disassemble your device; There’s a final instruction on the blue area to backtrack the guide to assemble it back.) That’s what I did.
