Introduzione
Use this guide to replace a broken AirPort antenna.
Parti
Nessuna parte specificata.
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use the flat end of a spudger to pry the subwoofer/right speaker cable connector up off its socket on the logic board.
Disconnect the camera cable by sliding it horizontally out of its socket.
If you see a small plastic retainer stuck to the logic board that prevents the camera cable from sliding out, peel it up carefully from the logic board. Apply a little heat from a hair dryer or heat gun if necessary to help soften the adhesive holding it in place. Do not attempt to forcibly disconnect the cable with the retainer in place.
If you still have trouble, use the point of a spudger to push at each side of the connector and "walk" it slowly from its socket.
Grab the clutch cover as shown and slide it toward the right side of the display.
Use the tip of a spudger to pry both AirPort antenna connectors out of their sockets on the AirPort board.
Remove the four 3 mm Phillips screws securing the antenna bracket to the display.
Altre 35 persone hanno completato questa guida.
4 Commenti
Hi,
I recently asked a similar question about the guide for replacing an AirPort Card. Where did you buy (a link would be amazing) the AirPort antenna for this specific laptop? Thanks.
-josh
Hi: Why i cannot find anywhere the new antenna for the fix? Mine is broken and I need a new one... All airport cards I can find seems not compatible with a mid2010 MacBook Pro
