Salta al contenuto principale
Sostituzione case superiore MacBook Pro 13" Unibody metà 2009
Cosa ti serve
  1. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009, Rimuovi le viti del case inferiore: passo 1, immagine 1 di 1
    • Rimuovi le dieci viti seguenti, che fissano il case inferiore al MacBook Pro Unibody da 13":
    • Sette viti con testa a croce da 3 mm.
    • Tre viti con testa a croce da 13,5 mm.
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - Replica
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Replica
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Replica
    I use a magnetic mat and place the screws in order on that :)
    Cary B - Replica
  2. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009, Solleva e rimuovi il case inferiore: passo 2, immagine 1 di 1
    • Solleva leggermente il case inferiore e spingilo verso la parte posteriore del computer per liberare le linguette di montaggio.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Replica
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - Replica
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009, Batteria: passo 3, immagine 1 di 1
    • Per precauzione, suggeriamo di scollegare il connettore della batteria dalla scheda logica per evitare eventuali scariche elettriche.
    • Mediante l'estremità piatta di uno spudger, sollevare il connettore del cavo della batteria dal connettore femmina sulla scheda logica staccandolo da questa.
    Citazione da gansodesoya:
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - Replica
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - Replica
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - Replica
  4. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009, Ventola: passo 4, immagine 1 di 3 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009, Ventola: passo 4, immagine 2 di 3 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009, Ventola: passo 4, immagine 3 di 3
    • Usa uno spudger per scollegare il connettore della ventola dalla sua presa sollevandolo dalla scheda madre.
    • Può essere utile ruotare lo spudger da sotto il cavo della ventola per scollegare il connettore.
    • La presa e il connettore della ventola sono mostrati nella seconda e terza immagine. Stai attento a non rompere la presa in plastica sulla scheda madre mentre fai leva con lo spudger per scollegare il connettore. La disposizione della scheda madre nella seconda immagine può essere leggermente diversa per il tuo dispositivo, ma la presa è identica.
    I just soldered it back on. . . I tried to clean the pads with braid first, but it didn't do much so I don't think that's necessary. I first supper-glued it in place with the pins on the pads and then I put a tiny dab of solder on each pin/pad. Plugged in the fan and i works!
    Ron Hudson - Replica
    Just the answer I was looking for Ron! Awesome work buddy!
    lucasjmenzie -
    i recommend not to use the spudger. you damage more than by unpluggin the plug by hand. just simply pull the cable close to the plug of the old fan softly upwards out. the plug than comes easily out. put the new fan in and push the new plug by hand in. it is much easier than using a spudger. i also started with a spudger but nearly broke the plug out, so i watched a youtube tutorial and learned about it…
    andre - Replica
  5. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 5, immagine 1 di 1
    • Svita le seguenti tre viti che fissano la ventola al case superiore:
    • Una vite a croce Phillips da 6,5 mm
    • Una vite a croce Phillips da 5,5 mm
    • Una vite a croce Phillips da 4,5 mm
  6. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 6, immagine 1 di 1
    • Solleva la ventola dal case superiore.
  7. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009, Scheda madre: passo 7, immagine 1 di 3 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009, Scheda madre: passo 7, immagine 2 di 3 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009, Scheda madre: passo 7, immagine 3 di 3
    • Prendi l'aletta in plastica fissata al blocco del cavo dati dello schermo e ruotala verso l'ingresso DC del portatile.
    • Sfila il cavo dati dello schermo dalla sua presa, verso l'ingresso DC del portatile.
  8. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 8, immagine 1 di 2 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 8, immagine 2 di 2
    • Svita le seguenti due viti che fissano la staffa del cavo dati dello schermo al case superiore:
    • Una vite a croce Phillips da 7 mm
    • Una vite a croce Phillips da 5 mm
    • Solleva la staffa del cavo dati dello schermo dal case superiore.
    Mine are Torx and got an extra clamp for the cable, just above the left screw
    Martin - Replica
    If you only want to replace the DC-in board, stop here and GOTO 17 (and DO NOT 4 and 6).
    When the Logic board is loose, lift it up on the Harddrive end and shift slightly towards the HD, so that the USB connectors at the outside come free from under the case rim and the board can be lifted up a bit. Then there´s enough room to move the DC in board, pull the cable out with a pair of tweezers, wriggle it out from under the microphone cable and wriggle the new connector in. It can be pushed into the socket with tweezers or a small screwdriver. This worked perfect for me.
    Be careful not to bend the logic board, but otherwise I think there´s much less risk of messing anything up with all the connectors and bits and pieces that need to be loosened and fastened.
    Mike - Replica
  9. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 9, immagine 1 di 1
    • Usa la parte piatta di uno spudger per scollegare il connettore del subwoofer e speaker destro dalla scheda madre.
  10. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 10, immagine 1 di 1
    • In questo passaggio scollegherai il cavo della fotocamera. La maggior parte delle macchine hanno un piccolo blocco automatico adesivo incastrato sulla scheda madre per tenere fermo il connettore. Prima di scollegare il cavo, assicurati che questo blocco sia spostato.
    • Tira il cavo della fotocamera verso il lettore CD per scollegarlo dalla scheda madre.
    • Questa presa è in metallo e si piega facilmente. Assicurati di allineare il connettore con la sua presa sulla scheda madre prima di collegare le due parti.
    There is a small piece just below this connector which is just an adhesive block to keep the connector from coming out. It is easiest to peel it up first with a fingernail or spudger then remove the cable. Likewise reinsert the cable before reapplying the adhesive safety stop.
    Justin Jett - Replica
    I couldn't reconnect this cable correctly, so my camera is not working anymore.
    It doesn't matter to me, I didn't used the camera that often...
    But the Ambient Light Sensor uses the camera to control keyboard lighting, so I wasn't able to see my keyboard in the dark anymore... :(
    If you have the same problem, after a couple of google hits I've found this app: https://www.macupdate.com/app/mac/22151/...
    Problem solved! YAY!
    PS: be careful because WIFI passes through this cable as well!!!!
    simbass - Replica
    Look at the photo intently. The connector is inserting not in parallel, but at a slight angle. The bottom corner of the connector is slightly ahead. It is important! Singular metod to insert it.
    Vladimir -
  11. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 11, immagine 1 di 3 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 11, immagine 2 di 3 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 11, immagine 3 di 3
    • Usa la parte piatta di uno spudger per scollegare i connettori dei cavi del lettore CD, del disco rigido e del trackpad dalla scheda madre.
  12. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 12, immagine 1 di 3 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 12, immagine 2 di 3 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 12, immagine 3 di 3
    • Usa un'unghia o la punta di uno spudger per ruotare verso l'alto l'aletta di bloccaggio sul connettore ZIF del cavo della tastiera.
    • Usa lo spudger per sfilare il cavo della tastiera dalla sua presa.
    When reinserting the keyboard ribbon cable, make sure you push it in all the way (two plastic tools are helpful - one to push it down flat, the other to coax it all the way in). For 3 days after replacing a top case, my MacBook Pro 13" wouldn't start up. I thought the main logic board was fried too. However, reinserting the keyboard ribbon cable again, this time perhaps 1mm farther in, and it started up again! I did the same for the "keyboard backlight ribbon cable" (i.e. reinserted it just to make sure). Really not sure which completed the circuit so is would start, but I suspect the keyboard ribbon cable.
    amiller770 - Replica
    Citazione da amiller770:
    I usually use a piece of sticky transparent office tape and stick it over the flat cable a bit further away from the mating part then pull on it. There is no better way to force the flat cable into a stiff connector without damaging the fragile cable.
    Leo Bodnar - Replica
    As others have stated, if the keyboard ribbon cable isn't fully inserted the MBP will not power on. Leo Bodnar's recommendation to use a piece of transparent office tape did the trick for me. Many thanks Leo!
    Matthew Rankin - Replica
    Inserting the ribbon cable for the keyboard was really difficult, but i was able to get it in using a piece of tape and pulling it up, just like the tape on the keyboard backlight.
    Kelly Legner - Replica
    Using a piece of tape is sheer genius Kelly. My mom once said her definition of genius was an idea that, when you hear it, you say to yourself, “now why didn’t I think of that?” But you never would have thought of it. Brava (or bravo) Kelly!
    JonnyLine -
  13. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 13, immagine 1 di 1
    • Rimuovi la piccola striscia di nastro nero dalla presa del cavo a nastro della retroilluminazione della tastiera.
  14. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 14, immagine 1 di 3 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 14, immagine 2 di 3 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 14, immagine 3 di 3
    • Usa la punta di uno spudger per ruotare verso l'alto l'aletta di bloccaggio sul connettore ZIF del cavo della retroilluminazione della tastiera.
    • Usa lo spudger per sfilare il cavo a nastro della retroilluminazione della tastiera dalla sua presa.
  15. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 15, immagine 1 di 1
    • Usa la parte piatta di uno spudger scollegare il connettore dell'indicatore della batteria sollevandolo dalla sua presa sulla scheda madre.
  16. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 16, immagine 1 di 1
    • Usa la punta di uno spudger per rimuovere il microfono dall'adesivo che lo fissa alla scocca superiore.
  17. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 17, immagine 1 di 1
    • Svita le seguenti viti:
    • Cinque viti a croce Phillips da 3,1 mm
    • Due viti a croce Phillips da 3,9 mm
    • Due viti a croce Phillips da 7 mm dalla scheda d'ingresso DC.
  18. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 18, immagine 1 di 2 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 18, immagine 2 di 2
    • Svita le seguenti viti Tri-point che fissano la batteria al case superiore:
    • Una vite Tri-point da 5,5 mm
    • Una vite Tri-point da 13,5 mm
    • Solleva la batteria dal case superiore.
  19. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 19, immagine 1 di 2 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 19, immagine 2 di 2
    • Solleva la scheda madre dal suo bordo sinistro e continua finché le porte non escono dal lato del case superiore.
    • Tira la schema madre lontano dal bordo del case superiore e rimuovila, stando attento alla scheda d'ingresso DC che potrebbe impigliarsi.
    • Stai attento a non strappare la presa delicata del connettore del gruppo del microfono.
    When putting the logic board back in place, it's easier to angle the mic down in it's place as you are placing the board in, rather than after the board is seated.
  20. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009, Case superiore: passo 20, immagine 1 di 2 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009, Case superiore: passo 20, immagine 2 di 2
    • Svita le due viti a croce Phillips che fissano la staffa del disco rigido al case superiore.
    • Queste viti resteranno intrappolate nella staffa del disco rigido.
    • Solleva la staffa del disco rigido dal case superiore.
  21. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 21, immagine 1 di 1
    • Solleva il disco rigido dal suo bordo libero e tiralo fuori dal case, stando attento al cavo che lo collega al portatile.
  22. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 22, immagine 1 di 1
    • Scollega il disco rigido tirando il suo connettore lontano dal disco stesso.
  23. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 23, immagine 1 di 2 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 23, immagine 2 di 2
    • Svita le seguenti quattro viti che fissano il cavo del disco rigido e del sensore IR al case superiore:
    • Due viti a croce Phillips da 1,5 mm
    • Due viti a croce Phillips da 4 mm
    • Sfila la staffa del disco rigido e del sensore IR dal bordo del case superiore.
    • Separa attentamente il cavo del disco rigido e del sensore IR dal case superiore.
  24. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 24, immagine 1 di 2 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 24, immagine 2 di 2
    • Svita le due viti a croce Phillips che fissano il subwoofer al case superiore.
    • La vite più lunga (8,2 mm) è a destra. Quella più corta (5 mm) è a sinistra.
    • Il subwoofer è ancora collegato allo speaker destro, quindi non rimuoverlo ancora.
    • Solleva il subwoofer dal lettore CD ed appoggialo sopra il portatile.
  25. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 25, immagine 1 di 2 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 25, immagine 2 di 2
    • Svita le due viti a croce Phillips da 9,2 mm che fissano la staffa del cavo della fotocamera al case superiore.
    • La vite più interna potrebbe restare incastrata nel cavo della fotocamera.
    • Se hai la versione di metà 2010, la tua staffa del cavo della fotocamera potrebbe essere leggermente diversa, ma la procedura è la stessa.
    • Solleva la staffa del cavo della fotocamera dal case superiore.
  26. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 26, immagine 1 di 2 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 26, immagine 2 di 2
    • Svita le tre viti a croce Phillips da 2,5 mm che fissano il lettore CD al case superiore.
    • Solleva il lettore CD dal bordo destro e rimuovilo dal portatile.
  27. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 27, immagine 1 di 1
    • Rimuovi il piccolo pezzo di nastro adesivo nero che copre il cavo dello speaker destro.
    • Stai attento, in quanto il cavo a nastro del tasto di accensione è direttamente sotto questo pezzo di nastro.
  28. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 28, immagine 1 di 1
    • Usa la punta di uno spudger per sollevare lo speaker destro dall'adesivo che lo fissa al case superiore.
  29. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 29, immagine 1 di 1
    • Solleva il subwoofer e il gruppo dello speaker destro dal case superiore.
  30. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 30, immagine 1 di 2 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 30, immagine 2 di 2
    • Svita le due viti Torx T8 esterne da 6 mm che fissano entrambi i lati dello schermo al case superiore (4 viti in totale).
    • Durante il rimontaggio, svita di un quarto di giro la vite interna Torx da 6 mm e allinea delicatamente lo schermo e il case superiore prima di avvitare le viti Torx esterne da 6 mm. Dopo aver allineato lo schermo e il case, stringi le viti Torx interne da 6 mm, quindi avvita e stringi le viti Torx esterne da 6 mm.
    When re-assembling everything, you'll need to back out the inner screws a bit and align the upper case and display. After aligning them, tighten the inner screws again, then insert and tighten the outer screws.
    bradeyh - Replica
  31. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 31, immagine 1 di 1
    • Apri il tuo MacBook Pro in modo che lo schermo sia perpendicolare al case superiore.
    • Appoggia il tup MacBook Pro aperto come mostato.
    • Mentre tieni insieme lo schermo e il case superiore insieme con la mano sinistra, svita la vite Torx da 6 mm restante dalla staffa inferiore dello schermo.
  32. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 32, immagine 1 di 1
    • Assicurati di tenere insieme lo schermo e il case superiore con la mano sinistra. Non farlo potrebbe far cadere lo schermo/case superiore, potenzialmente danneggiando ogni componente.
    • Svita l'ultima vite Torx da 6 mm rimasta che fissa lo schermo al case superiore.
  33. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 33, immagine 1 di 3 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 33, immagine 2 di 3 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 33, immagine 3 di 3
    • Prendi il case superiore con la mano destra e ruotalo leggermente verso il bordo superiore dello schermo in modo che la staffa superiore dello schermo superi il bordo del case superiore.
    • Ruota leggermente lo schermo lontano dal case superiore.
    • Solleva lo schermo ed allontanalo dal case superiore, stando attento ad ogni staffa o cavo che potrebbe impigliarsi.
  34. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009, Case superiore: passo 34, immagine 1 di 1
    • Svita le quattro vivi a croce Phillips da 1,2 mm evidenziate in rosso.
  35. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 35, immagine 1 di 1
    • Stacca attentamente il bordo del trackpad più vicino alla tastiera dal suo alloggio nel case superiore spingendolo via dalle staffe attaccate al case superiore.
    • Sfila il cavo del trackpad dalla sua apertura nel case superiore.
    I concur with Anonymous 596. There is a support wall that runs front to back, under keyboard, held down by 2 Phillips screws that will need to be removed & transferred to new upper case. You can see it being touched by index finger in this pic.
    Macrepair SF - Replica
  36. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 36, immagine 1 di 1
    • Tira via il trackpad dal bordo esterno del case superiore.
    • Rimuovi il trackpad e mettilo da parte.
    There's a missing step here. In addition to the trackpad, there's an aluminum structural piece that sits under the center of the keyboard, that has to be migrated from old to new case. It's clearly shown to the left of the repair-person's right hand in step 44.
    anonymous 596 - Replica
  37. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 37, immagine 1 di 1
    • Nei prossimi passaggi, dovrai lavorare sul nuovo case superiore.
    • Usa un cacciavite Torx T6 per avvitare appena la vite da 1,1 mm inclusa con il tuo nuovo case superiore nel foro vicino al centro dell'apertura del tackpad.
    • Stringila solo di un giro per ora.
    I bought a used replacement case and had to move a few parts from the old case to the replacement. This included the battery indicator cable, the clips for the trackpad and the bracket in the center of the top case. So worth it at this point to compare your old and replacement case to be sure everything you need is there.
    Ron - Replica
    my new case came with the set screw already installed, and i couldn’t loosen it. i didn’t want to strip it and cause a bigger problem, so i left it alone. the trackpad seems to work fine so far regardless, although i may take the bottom case off and play with it a little if i get a chance.
    i also (just like Ron) had to move the trackpad clips, battery indicator and center bracket to the new case. they were not included.
    Matt - Replica
  38. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 38, immagine 1 di 2 Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 38, immagine 2 di 2
    • Infila attentamente il cavo del tackpad originale nella sua fessura nel tuo nuovo case superiore.
    • Usa una mano per tenere fermo il cavo del trackpad mentre infili le due alette di bloccaggio nel bordo esterno del trackpad sotto il coperchio del case superiore.
    • Tira il cavo del trackpad mentre lo appoggi nel suo alloggio nel tuo nuovo case superiore.
  39. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 39, immagine 1 di 1
    • Avvita una vite a croce Phillips da 1,2 mm in ogni foro esterno del trackpad (due viti in totale).
    • Avviterai le altre in un attimo.
    • Stringi le viti, quindi svitale di un quarto di giro per poter allineare il trackpad nei prossimi passaggi.
  40. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 40, immagine 1 di 1
    • Mentre continui a provare a cliccare il trackpad, avvita delicatamente la vite Torx T6 finché il click ti sembra tornato come prima di smontarlo.
    • Puoi capire quando la vite è stretta dal suono del click del trackpad. Se la vite non è stretta abbastanza, il trackpad avrà una corsa eccessiva prima di fare click. Se è troppo stretta, il trackpad si cliccherà troppo facilmente e non emetterà il suo classico suono corposo.
  41. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 41, immagine 1 di 1
    • Ora gira il case superiore in modo che la tastiera sia rivolta verso l'alto.
    • Allinea il trackpad in modo che sia centrato nella sua apertura nel case superiore.
    Pour l’alignement du Tradpad mettez sur les 4 cotés des morceaux de feuille A4😜.
    Caruso - Replica
  42. Sostituzione case superiore MacBook Pro 13" Unibody metà 2009: passo 42, immagine 1 di 1
    • Stingi le due viti esterne sul bordo interno del trackpad e controlla l'allineamento sull'esterno del case superiore.
    • Se l'allineamento ti sembra buono, avvita il resto delle viti a croce Phillips sul bordo inferno del trackpad.
    • Prima di rimontare la tua macchina, controlla che la vite centrale sia ancora avvitata in una posizione che faccia cliccare il trackpad correttamente.
    You can actually replace the keyboard alone fairly easily! I don't know why everyone says you have to replace the whole top case, because if you've got the guts to go this far, you might as well just peel back the illuminator cover and get to work pulling all those tiny screws in the keyboard... Just be careful when peeling up the black adhesive keyboard cover, because you will need to replace it. I used the edge of the ifixit Sesame tool (very thin flat metal opening tool) to carefully slip under any bits of adhesive, and had the keyboard exposed in no time. Also be careful because the clear plastic sheet is actually the keyboard illuminator. Once under all that, it's a mere 50 or so tiny screws, 2 screws in the power button backing, and you've got the keyboard out. Use a magnetized #000 phillips, it will make life much easier than anything else.
    Logan Bean - Replica
    Absolutely right. I just replaced a keyboard the same way without much problem but i just want to add that those tiny screws need extra care as the heads can get damaged very easily. If damaged, they become very difficult to remove.
    Masood -
    I did just that on my mid-2010 MacBook Pro about a month ago and sadly will have to do it to my wife's Early-2011 one next week. I was cleaning all the crap off her keyboard and apparently nuked the K and 0 keys on her keyboard. Probably my ply challenge was aligning the keyboard illuminator. It's still not aligned properly on mine so some keys are better lit than others, but otherwise it was a relatively easy fix and far cheaper than replacing the entire upper case.
    John Adam Wickliffe -
    I replaced my keyboard less than an hour ago. The biggest pain/most time consuming was reattaching the ZIF connector for the keyboard and backlight. No matter what I did I could not get the %#*@ thing to reattach. What sadist designs these things? I had to walk away from the project for an hour and finally success.
    All those screws will make you go crosseyed!
    Gordon - Replica
    It helps to put some tape along the cable going lengthwise to the cable, and then fold the end of the tape onto itself to give yourself something to hold onto. This will give you some leverage to get that puppy into the socket.
    maccentric -
    I’m glad you managed !!!
    I’m suffering :( take a part about 5 times…… ordered new (used) keyboard, the same results. I tested logic board in my daughter MAC, board works 100% no trouble ……. what could be wrong? there a secret how to reassemble keyboard parts together? I ripped a little bit black plastic thing, not top one with tiny connectors……
    In the end I have two keyboards, cleaned and taken a part, both of them acting identical when installed. Some keys respond by giving absolutely not relevant symbols, beeping noise come with almost every key i pressed…..
    Recovering after massive cappuccino spell after surprising hug :(((((
    Aleksandra Perry -
    I swear to post photo step by step, if I will achieve this one……….. assemble back to 100% working condition after total reassembling, ultrasonic cleaning and drying………. just keyboard panel.
    Give me nightmares :) will be first time I have so much trouble to fix………
    Aleksandra Perry -
    I'm wondering about putting it back together. Different wires and small parts etc were glued or adhered in some way to the case or sides or whatever, as it is put together in the beginning. Is that just to make it easier to put it back together? Should I try to stick them back the way they were with something? Can you use tape or glue if it's just a wire? I wouldn't want to use something that would melt...or is this not something to worry apout?
    ingwis - Replica
    I just used 1/4 polymide tape, and iFixit double sided tape. Works like a champ.
    Brent Hillyer -
Conclusione
Per rimontare il tuo dispositivo, segui le istruzioni in ordine inverso.
Altre 47 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
2 Commenti
Very good tutorial. Guide was 100% accurate. As mentioned, make sure you have good quality tools, and follow the guide to be certain the right get tool is used for certain screws, I did strip one screw head, in my opinion not bad considering all the tiny screws! But now my MacBook works, and save me having to spend on a new MacBook!
Gabriel - Replica
Outstanding level of detail!!! Spot on directions.
Dan Coy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 54
Tutti i Tempi: 92,069
