Salta al contenuto principale
MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement
Cosa ti serve
  1. MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement, Lower Case: passo 1, immagine 1 di 1
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
  2. MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement: passo 2, immagine 1 di 2 MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement: passo 2, immagine 2 di 2
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement, Battery: passo 3, immagine 1 di 1
    • Disconnect the battery connector by pulling it straight out of its socket.
  4. MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement: passo 4, immagine 1 di 1
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
  5. MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement: passo 5, immagine 1 di 1
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement, AirPort/Bluetooth Bracket: passo 6, immagine 1 di 1
    • Remove the two Phillips screws securing the AirPort/Bluetooth bracket to the upper case.
  7. MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket Replacement: passo 7, immagine 1 di 1
    • Lift the AirPort/Bluetooth bracket out of the upper case.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 11,589
