Salta al contenuto principale
MacBook Air 11" Late 2010 Heat Sink Replacement
Cosa ti serve
  1. MacBook Air 11" Late 2010 Heat Sink Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Compra
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Late 2010 Heat Sink Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Late 2010 Heat Sink Replacement, Battery: passo 3, immagine 1 di 2 MacBook Air 11" Late 2010 Heat Sink Replacement, Battery: passo 3, immagine 2 di 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Late 2010 Heat Sink Replacement, Solid-State Drive: passo 4, immagine 1 di 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 11" Late 2010 Heat Sink Replacement: passo 5, immagine 1 di 2 MacBook Air 11" Late 2010 Heat Sink Replacement: passo 5, immagine 2 di 2
    • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
    • Do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  6. MacBook Air 11" Late 2010 Heat Sink Replacement, I/O Board Cable: passo 6, immagine 1 di 1
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  7. MacBook Air 11" Late 2010 Heat Sink Replacement: passo 7, immagine 1 di 1
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
  8. MacBook Air 11" Late 2010 Heat Sink Replacement, Fan: passo 8, immagine 1 di 1
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Air 11" Late 2010 Heat Sink Replacement: passo 9, immagine 1 di 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 3.6 mm T5 Torx screw
  10. MacBook Air 11" Late 2010 Heat Sink Replacement: passo 10, immagine 1 di 1
    • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
  11. MacBook Air 11" Late 2010 Heat Sink Replacement, Heat Sink: passo 11, immagine 1 di 1
    • Remove the eight 2.5 mm T5 Torx screws securing the heat sink to the logic board.
  12. MacBook Air 11" Late 2010 Heat Sink Replacement: passo 12, immagine 1 di 1
    • If the heat sink seems to be stuck to the logic board after removing all eight screws, use a spudger to carefully separate the heat sink from the faces of the CPU and GPU.
    • Remove the heat sink from the logic board.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 27
Tutti i Tempi: 9,584
