Salta al contenuto principale
MSI GS60 Ghost Pro 4K Gold Edition HDMI Port Replacement
Cosa ti serve
  1. MSI GS60 Ghost Pro 4K Gold Edition HDMI Port Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place this device back panel facing up.
  2. MSI GS60 Ghost Pro 4K Gold Edition HDMI Port Replacement: passo 2, immagine 1 di 1
    • Using the screwdriver, unscrew the highlighted 1.2mm Phillips head #0 screws which secure the back panel into place.
  3. MSI GS60 Ghost Pro 4K Gold Edition HDMI Port Replacement: passo 3, immagine 1 di 2 MSI GS60 Ghost Pro 4K Gold Edition HDMI Port Replacement: passo 3, immagine 2 di 2
    • Using the plastic opening tools, separate the back panel from the rest of the device.
    • Do this by firmly pressing the head of the tool into the space between the back panel, and the rest of the device.
  4. MSI GS60 Ghost Pro 4K Gold Edition HDMI Port Replacement, Battery: passo 4, immagine 1 di 1
    • Pull the back panel off.
  5. MSI GS60 Ghost Pro 4K Gold Edition HDMI Port Replacement: passo 5, immagine 1 di 1
    • Notice the L-shaped battery in the lower right corner of the opened laptop.
    • Disconnect the battery from the slot it is connected to. You'll need to push on the sides of the clip and pull.
  6. MSI GS60 Ghost Pro 4K Gold Edition HDMI Port Replacement: passo 6, immagine 1 di 2 MSI GS60 Ghost Pro 4K Gold Edition HDMI Port Replacement: passo 6, immagine 2 di 2
    • Lift up the battery with your fingers and remove it from the laptop.
    • Place the battery away from the laptop in a safe spot and insert your new battery by hooking it up to the slot you previously disconnected the old battery from.
  7. MSI GS60 Ghost Pro 4K Gold Edition HDMI Port Replacement, MotherBoard: passo 7, immagine 1 di 1
    • Unscrew the 4 1.2mm Phillips #0 screws connecting the motherboard to the laptop case.
    • Disconnect the wires connecting to the motherboard to the USB ports.
    • Disconnect the ribbon cables connecting the keyboard, and track pad of the device.
  8. MSI GS60 Ghost Pro 4K Gold Edition HDMI Port Replacement: passo 8, immagine 1 di 1
    • Lift the motherboard up and out of the device casing.
  9. MSI GS60 Ghost Pro 4K Gold Edition HDMI Port Replacement, HDMI Port: passo 9, immagine 1 di 1
    • Desolder the connections between the HDMI port and the motherboard.
    • Be careful not to damage other components of the motherboard during the process!
    • For tips on soldering, check out iFixit's How to Solder and Desolder Connections guide.
Conclusione
Jordan Williams
Membro da: 10/19/17
201 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 463
