Salta al contenuto principale
Logitech Webcam Pro 9000 USB Connection Replacement
Cosa ti serve
  1. Logitech Webcam Pro 9000 USB Connection Replacement, Front and Back Cover: passo 1, immagine 1 di 2 Logitech Webcam Pro 9000 USB Connection Replacement, Front and Back Cover: passo 1, immagine 2 di 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 USB Connection Replacement: passo 2, immagine 1 di 2 Logitech Webcam Pro 9000 USB Connection Replacement: passo 2, immagine 2 di 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 USB Connection Replacement, USB Connection: passo 3, immagine 1 di 2 Logitech Webcam Pro 9000 USB Connection Replacement, USB Connection: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to grasp the white wire connector on the back of the motherboard.
    • Wiggle the connector back and forth to remove it from the socket.
  4. Logitech Webcam Pro 9000 USB Connection Replacement: passo 4, immagine 1 di 2 Logitech Webcam Pro 9000 USB Connection Replacement: passo 4, immagine 2 di 2
    • Desolder the joint on the front of the motherboard to completely detach the USB cable.
    • Follow this link to learn how to properly solder and desolder your parts.
Conclusione
Cory Davis
Membro da: 04/14/13
236 Reputazione
4 Guide realizzate
Cal Poly, Team 12-34, Amido Spring 2013 Membro di Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Membri
16 Guide realizzate
Un commento
what is the connector called
Anirudh Krishnan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,024
