Salta al contenuto principale
Introduzione
This guide will lead you in desoldering the connections between the camera and the motherboard.
  1. Remove the two 8 mm Phillips #0 screws on the back cover. The motherboard is attaching the two covers together, so don't separate them entirely just yet.
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard is attaching the two covers together, so don't separate them entirely just yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Remove the four 6mm Phillips#0 screws  connecting the motherboard and front cover. DO NOT detach the wire connecting the motherboard to the front cover.
    • Remove the four 6mm Phillips#0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Remove the two 8mm Phillips#0 screws on the back of the motherboard.
    • Remove the two 8mm Phillips#0 screws on the back of the motherboard.
  4. Remove the camera from the motherboard by desoldering the two connections as shown. Follow this link to learn how to properly solder and desolder your parts. Follow this link to learn how to properly solder and desolder your parts.
    • Remove the camera from the motherboard by desoldering the two connections as shown.
    • Follow this link to learn how to properly solder and desolder your parts.
Conclusione
nieko
Membro da: 18/04/2013
63 Reputazione
2 Guide realizzate
Cal Poly, Team 12-34, Amido Spring 2013 Membro di Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,736
