Salta al contenuto principale
Logitech VX Nano Wireless Mouse Opening Procedure
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Logitech VX Nano Wireless Mouse Opening Procedure, Remove batteries and nano receiver: passo 1, immagine 1 di 2 Logitech VX Nano Wireless Mouse Opening Procedure, Remove batteries and nano receiver: passo 1, immagine 2 di 2
    • Pull down on the battery release tab to remove the battery cover.
    • Remove battery cover.
  2. Logitech VX Nano Wireless Mouse Opening Procedure: passo 2, immagine 1 di 2 Logitech VX Nano Wireless Mouse Opening Procedure: passo 2, immagine 2 di 2
    • Pull the battery release tab away from the mouse so the two AA batteries come out.
  3. Logitech VX Nano Wireless Mouse Opening Procedure: passo 3, immagine 1 di 1
    • If the Nano Receiver is still in the mouse and not in your computer, remove it by pushing on the bright orange button. It should pop right out!
  4. Logitech VX Nano Wireless Mouse Opening Procedure, Open the mouse: passo 4, immagine 1 di 1
    • Find and remove the screws at the bottom of the battery compartment:
    • Two 6 mm Phillips #1 screws
    • When removing these two screws, it can be helpful to hold the plastic battery tab out of the way of your screwdriver.
  5. Logitech VX Nano Wireless Mouse Opening Procedure: passo 5, immagine 1 di 2 Logitech VX Nano Wireless Mouse Opening Procedure: passo 5, immagine 2 di 2
    • Use an opening pick to get underneath the corner of one of the adhesive skates.
    • As you start to remove the skate, make sure that the opening pick is underneath the entire adhesive pad—otherwise you run the risk of splitting the pad in half.
    • Continue to push the opening pick between the adhesive and the mouse case, slowly working the adhesive away from the case.
    • Repeat this same process for the two other skates.
    • Remove any old adhesive residue before applying new mouse skates.
  6. Logitech VX Nano Wireless Mouse Opening Procedure: passo 6, immagine 1 di 1
    • Remove the screws from the backside of the mouse:
    • Three 6 mm Phillips #1 screws
    • The top shell and bottom case are no longer connected. Keep the mouse steady so you can carefully remove the upper shell in the next step.
  7. Logitech VX Nano Wireless Mouse Opening Procedure: passo 7, immagine 1 di 2 Logitech VX Nano Wireless Mouse Opening Procedure: passo 7, immagine 2 di 2
    • Carefully separate the top plastic shell from the bottom case.
    • Remove the top shell.
Conclusione
Carsten Frauenheim
Membro da: 03/10/20
113.715 Reputazione
338 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 38
