Salta al contenuto principale
Logitech Harmony Smart Control Reset Button Replacement
Cosa ti serve
  1. Logitech Harmony Smart Control Reset Button Replacement, Reset Button: passo 1, immagine 1 di 2 Logitech Harmony Smart Control Reset Button Replacement, Reset Button: passo 1, immagine 2 di 2
    • Using a plastic opening tool, lift up the rubber pad.
    • From the bottom of the device, with your fingers, pull back the rubber pad. This will expose the screw holes.
    • On the bottom of the hub, repeat the step above for the second rubber pad.
  2. Logitech Harmony Smart Control Reset Button Replacement: passo 2, immagine 1 di 2 Logitech Harmony Smart Control Reset Button Replacement: passo 2, immagine 2 di 2
    • With the PH00 bit, remove the four 6mm Phillips screws.
  3. Logitech Harmony Smart Control Reset Button Replacement: passo 3, immagine 1 di 2 Logitech Harmony Smart Control Reset Button Replacement: passo 3, immagine 2 di 2
    • With the plastic opening tool, separate the pieces of plastic from each other
  4. Logitech Harmony Smart Control Reset Button Replacement: passo 4, immagine 1 di 2 Logitech Harmony Smart Control Reset Button Replacement: passo 4, immagine 2 di 2
    • With the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Reset Button Replacement: passo 5, immagine 1 di 3 Logitech Harmony Smart Control Reset Button Replacement: passo 5, immagine 2 di 3 Logitech Harmony Smart Control Reset Button Replacement: passo 5, immagine 3 di 3
    • From the yellow corner, pry the circuit board from the housing..
  6. Logitech Harmony Smart Control Reset Button Replacement: passo 6, immagine 1 di 3 Logitech Harmony Smart Control Reset Button Replacement: passo 6, immagine 2 di 3 Logitech Harmony Smart Control Reset Button Replacement: passo 6, immagine 3 di 3
    • Locate the defective reset button.
    • Turn the board around to expose the reset solder.
    • Using soldering iron, remove solder and reset button. Replace reset button and solder.
Conclusione
IUPUI, Team 3-2, Harley Fall 2015 Membro di IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,054
