Salta al contenuto principale
Logitech Harmony Smart Control Hub Light Bulb Replacement
Cosa ti serve
  1. Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: passo 1, immagine 1 di 2 Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: passo 1, immagine 2 di 2
    • Use a spudger to lift up one of the rubber pads on the bottom of the hub.
    • Pull back the rubber pad and remove it. This will expose the screws on the bottom of the device.
    • Repeat for the second rubber pad.
  2. Logitech Harmony Smart Control Hub Light Bulb Replacement: passo 2, immagine 1 di 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: passo 2, immagine 2 di 2
    • Use a PH00 screwdriver bit to remove the four 6mm Phillips screws on the bottom of the device.
  3. Logitech Harmony Smart Control Hub Light Bulb Replacement: passo 3, immagine 1 di 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: passo 3, immagine 2 di 2
    • Use a spudger to separate the top and bottom pieces of the device.
  4. Logitech Harmony Smart Control Hub Light Bulb Replacement: passo 4, immagine 1 di 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: passo 4, immagine 2 di 2
    • Use the PH00 screwdriver bit to unscrew the three 4mm Phillips screws on the control board.
  5. Logitech Harmony Smart Control Hub Light Bulb Replacement: passo 5, immagine 1 di 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: passo 5, immagine 2 di 2
    • Place the end of the opening tool under the yellow corner of the circuit board as shown.
    • Gently push upward to pry the board from its housing.
  6. Logitech Harmony Smart Control Hub Light Bulb Replacement: passo 6, immagine 1 di 3 Logitech Harmony Smart Control Hub Light Bulb Replacement: passo 6, immagine 2 di 3 Logitech Harmony Smart Control Hub Light Bulb Replacement: passo 6, immagine 3 di 3
    • Determine which of the five bulbs are defective.
    • Turn the board over to expose the bulb solder.
    • Using a soldering iron, remove the solder and bulb. Replace with a new bulb and re-solder.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team 3-2, Harley Fall 2015 Membro di IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 653
