Salta al contenuto principale
Logitech Harmony Smart Control Charging Port Replacement
Cosa ti serve
  1. Logitech Harmony Smart Control Charging Port Replacement, Charging Port: passo 1, immagine 1 di 2 Logitech Harmony Smart Control Charging Port Replacement, Charging Port: passo 1, immagine 2 di 2
    • Use the plastic opening tool to lift up the rubber pad.
    • With your fingers, pull back the rubber pad. This will expose the screw holes on the bottom of the device.
    • Repeat the step above for the second rubber pad on the bottom of the hub.
  2. Logitech Harmony Smart Control Charging Port Replacement: passo 2, immagine 1 di 2 Logitech Harmony Smart Control Charging Port Replacement: passo 2, immagine 2 di 2
    • Using the PH00 bit, remove the four 6mm Phillips screws
  3. Logitech Harmony Smart Control Charging Port Replacement: passo 3, immagine 1 di 2 Logitech Harmony Smart Control Charging Port Replacement: passo 3, immagine 2 di 2
    • Use the plastic opening tool to pry open and separate the pieces of plastic from each other.
  4. Logitech Harmony Smart Control Charging Port Replacement: passo 4, immagine 1 di 2 Logitech Harmony Smart Control Charging Port Replacement: passo 4, immagine 2 di 2
    • Using the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Charging Port Replacement: passo 5, immagine 1 di 3 Logitech Harmony Smart Control Charging Port Replacement: passo 5, immagine 2 di 3 Logitech Harmony Smart Control Charging Port Replacement: passo 5, immagine 3 di 3
    • Starting at the yellow corner, use a plastic opening tool to pry the circuit board from the housing.
  6. Logitech Harmony Smart Control Charging Port Replacement: passo 6, immagine 1 di 3 Logitech Harmony Smart Control Charging Port Replacement: passo 6, immagine 2 di 3 Logitech Harmony Smart Control Charging Port Replacement: passo 6, immagine 3 di 3
    • Locate the defective charging port.
    • Turn the circuit board over to expose the charging solder.
    • Using a soldering iron, remove the solder and the charging port. Install a new charging port and solder.
Conclusione
IUPUI, Team 3-2, Harley Fall 2015 Membro di IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 861
