Salta al contenuto principale
Logitech G920 Driving Force XYAB Buttons Replacement
Cosa ti serve
  1. Logitech G920 Driving Force XYAB Buttons Replacement, Steering Wheel Motherboard: passo 1, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
    • Only three of the five screws are visible from each side of the wheel due to the center unit.
    Chiedi a FixBot
  2. Logitech G920 Driving Force XYAB Buttons Replacement: passo 2, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the 5 mm screws holding the bumpers in place.
    Chiedi a FixBot
  3. Logitech G920 Driving Force XYAB Buttons Replacement: passo 3, immagine 1 di 2 Logitech G920 Driving Force XYAB Buttons Replacement: passo 3, immagine 2 di 2
    • Using the TR25 Torx Security Screwdriver, remove the six 23.8 mm screws holding the face plate together.
    • Remove the face plate from the steering wheel.
    Chiedi a FixBot
  4. Logitech G920 Driving Force XYAB Buttons Replacement: passo 4, immagine 1 di 2 Logitech G920 Driving Force XYAB Buttons Replacement: passo 4, immagine 2 di 2
    • Remove the wheel from the main steering wheel console.
    • Ensure this is done carefully as to not damage the connection wire.
    Chiedi a FixBot
  5. Logitech G920 Driving Force XYAB Buttons Replacement: passo 5, immagine 1 di 2 Logitech G920 Driving Force XYAB Buttons Replacement: passo 5, immagine 2 di 2
    • Remove the eight 7.5 mm screws holding the steering wheel motherboard in place using a Phillips #0 screwdriver.
    • Remove the steering wheel motherboard.
    Chiedi a FixBot
  6. Logitech G920 Driving Force XYAB Buttons Replacement, XYAB Buttons: passo 6, immagine 1 di 1
    • Remove the XYAB buttons from the back of the steering wheel.
    Chiedi a FixBot
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 21
Ultimi 30 giorni: 89
Tutti i Tempi: 1,128
