Introduzione
If the LEDs on your Logitech G X56 HOTAS Throttle flicker, dim, or stop working—whether individually or in entire sections—it may be due to a failing LED board. This guide will walk you through the steps to replace one or multiple LED boards to restore consistent illumination. Before beginning, ensure the throttle is not set to a lighting or power setting that could cause flickering, as some effects may be software-controlled rather than hardware-related.
If you're unfamiliar with soldering, please review the How to Solder and Desolder Connections guide and take appropriate precautions before beginning.
Cosa ti serve
Disconnect all of the motherboard connectors by pulling them straight up and out of their sockets.
Each LED Board uses the LEDs to hold it against the base plate. It also has a single cable set to the logic and power board.
