Salta al contenuto principale
Logitech G X56 HOTAS Throttle LED Board Replacement
Cosa ti serve
  1. Logitech G X56 HOTAS Throttle LED Board Replacement, Label Plate: passo 1, immagine 1 di 2 Logitech G X56 HOTAS Throttle LED Board Replacement, Label Plate: passo 1, immagine 2 di 2
    • Remove the eight 8.6 mm long 1.5 mm hex screws from the label plate.
  2. Logitech G X56 HOTAS Throttle LED Board Replacement: passo 2, immagine 1 di 1
    • Use an opening tool to pry off the mode switch knob.
  3. Logitech G X56 HOTAS Throttle LED Board Replacement: passo 3, immagine 1 di 3 Logitech G X56 HOTAS Throttle LED Board Replacement: passo 3, immagine 2 di 3 Logitech G X56 HOTAS Throttle LED Board Replacement: passo 3, immagine 3 di 3
    • Remove the eight 12.5 mm long Phillips #1 screws from the underside of the label plate.
    • These screws are plastic! Be very careful when applying force.
  4. Logitech G X56 HOTAS Throttle LED Board Replacement: passo 4, immagine 1 di 2 Logitech G X56 HOTAS Throttle LED Board Replacement: passo 4, immagine 2 di 2
    • Place the throttle right side up again, using the bottom panel as a coaster.
    • Gently pry the label plate from the body of the throttle.
  5. Logitech G X56 HOTAS Throttle LED Board Replacement, Motherboard: passo 5, immagine 1 di 2 Logitech G X56 HOTAS Throttle LED Board Replacement, Motherboard: passo 5, immagine 2 di 2
    • Optional: Take a picture or mark each connector as you remove them for ease of reassembly.
    • Disconnect all of the motherboard connectors by pulling them straight up and out of their sockets.
  6. Logitech G X56 HOTAS Throttle LED Board Replacement: passo 6, immagine 1 di 2 Logitech G X56 HOTAS Throttle LED Board Replacement: passo 6, immagine 2 di 2
    • Remove the four 11.6 mm-long Phillips #0 screws that secure the motherboard.
  7. Logitech G X56 HOTAS Throttle LED Board Replacement: passo 7, immagine 1 di 1
    • Lift the motherboard from the base plate shell, carefully making sure to keep the USB power cable unstrained.
  8. Logitech G X56 HOTAS Throttle LED Board Replacement, LED Board: passo 8, immagine 1 di 2 Logitech G X56 HOTAS Throttle LED Board Replacement, LED Board: passo 8, immagine 2 di 2
    • Each LED Board uses the LEDs to hold it against the base plate. It also has a single cable set to the logic and power board.
  9. Logitech G X56 HOTAS Throttle LED Board Replacement: passo 9, immagine 1 di 2 Logitech G X56 HOTAS Throttle LED Board Replacement: passo 9, immagine 2 di 2
    • Each of the LEDs needs to be removed with a soldering iron and your choice of solder wick or solder sucker.
    • Once free of the solder, the LED must be pushed through to the front.
  10. Logitech G X56 HOTAS Throttle LED Board Replacement: passo 10, immagine 1 di 1
    • Gently Remove the LED board.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 151
