Introduzione
Follow this guide to replace and adjust the deflector chain and cable on a Little Wonder GX270 Maximum Output blower.
Cosa ti serve
The next two steps will show you how to remove the master link on the deflector chain.
The following steps show how to install a new deflector chain.
Note the center link on the deflector chain.
Note the middle tooth of the pivot.
Lift the deflector so that it is horizontal.
Turn the deflector knob clockwise to lock the deflector horizontally in the wide-open position.
Use the lever to open and close the deflector to check that cable is properly adjusted.
Repeat step 17, then step 22 but give the nut an additional clockwise turn.
Repeat steps 23–24.
Repeat step 17, then step 22 but give the nut an addition counterclockwise turn.
Repeat steps 23–24.
