Salta al contenuto principale
Lite-On iHAS324 Eject Button and Power LED Light Replacement
Cosa ti serve
  1. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Chassis: passo 1, immagine 1 di 2 Lite-On iHAS324 Eject Button and Power LED Light Replacement, Chassis: passo 1, immagine 2 di 2
    • Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
    • There may be resistance, do not be afraid to use force.
    • The tray should then pop open.
    • Pull out the tray so that it is fully extended.
  2. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 2, immagine 1 di 3 Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 2, immagine 2 di 3 Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 2, immagine 3 di 3
    • Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
  3. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 3, immagine 1 di 1
    • Pull the faceplate off the chassis.
    • Do NOT pull the faceplate all the way off the disc tray, because doing so can cause damage to the faceplate.
  4. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 4, immagine 1 di 1
    • Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
  5. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 5, immagine 1 di 1
    • Remove the bottom plate by lifting it off the device.
  6. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 6, immagine 1 di 1
    • Turn the device over.
    • Remove the top plate by pulling the sides and lifting the plate off.
  7. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray: passo 7, immagine 1 di 2 Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray: passo 7, immagine 2 di 2
    • Push the left tab in and slide the tray out on the left side.
    • Pull the gray plastic casing on the right side away from the tray.
    • Slide the right side of the tray out.
  8. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray Belt: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Take tweezers and remove the black tray belt from the gears carefully.
  9. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Eject Button and Power LED Light: passo 9, immagine 1 di 1
    • Flip the device over.
  10. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 10, immagine 1 di 1
    • Use a plastic opening tool to pull all three tabs, lifting up the circuit board as you go.
  11. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 11, immagine 1 di 1
    • Carefully lift the circuit board out of the plastic casing.
  12. Lite-On iHAS324 Eject Button and Power LED Light Replacement: passo 12, immagine 1 di 1
    • Using a solder wick, unsolder either the eject button or Power LED Light. Soldering Guide
    • Then, using a solder iron, replace them.
Conclusione
Baylor, Team 5-9, Williams Spring 2015 Membro di Baylor, Team 5-9, Williams Spring 2015
BU-WILLIAMS-S15S5G9
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 22
Tutti i Tempi: 997
