Cosa ti serve
Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
The tray should then pop open.
Pull out the tray so that it is fully extended.
Push the left tab in and slide the tray out on the left side.
Pull the gray plastic casing on the right side away from the tray.
Slide the right side of the tray out.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Take tweezers and remove the black tray belt from the gears carefully.
Using a solder wick, unsolder either the eject button or Power LED Light. Soldering Guide
Then, using a solder iron, replace them.
